12-09-2020 01:05 PM - edited 12-09-2020 03:13 PM
Refer to the diagram attached.
I'm trying to find out the path that frames/packets take from an ESXi host to the default gateway: 10.1.120.1 if link2 was used?
The show spanning-tree root on 5K_a shows that the root is the core switch (VSS) which is what is expected
The show spanning-tree root on 5K_b shows that the root is the vPC peer switch 5K_a.
There are a few vPC options that aren't enabled on neither vPC peer Primary nor vPC peer Secondary
Peer Switch --- Not enabled
Peer Gateway --- Not enabled
STP Root Primary/STP Root Secodary = Not enabled
VSS consists of two C6509s. BID 24764 for all VLANs
vPC Domain consists of two NX5Ks BID 32768 for all VLANs
vPC nx5k_a and nx5k_b uplinked to VSS via a port-channel/vPC (Po1/vPC1)
vPC nx5K_a and nx5K_b interconnected via a Peer-link port-channel (Po10)
ESXi host is attached to two vPC peer switches (configured in a vPC domain) with individual ports/orphan ports
On nx5k_a (Opertional Primary): the output of the "show spanning-tree root" command displays
Root Hello Max Fwd
Vlan Root ID Cost Time Age Dly Root Port
VLAN0001 24577 0000.0000.0001 1 2 20 15 port-channel1
VLAN080 24656 0000.0000.0001 1 2 20 15 port-channel1
VLAN088 24664 0000.0000.0001 1 2 20 15 port-channel1
VLAN0120 24696 0000.0000.0001 1 2 20 15 port-channel1
VLAN0122 24698 0000.0000.0001 1 2 20 15 port-channel1
VLAN0124 24700 0000.0000.0001 1 2 20 15 port-channel1
VLAN0126 24702 0000.0000.0001 1 2 20 15 port-channel1
VLAN0128 24704 0000.0000.0001 1 2 20 15 port-channel1
VLAN0140 24716 0000.0000.0001 1 2 20 15 port-channel1
VLAN0141 24717 0000.0000.0001 1 2 20 15 port-channel1
VLAN0150 24726 0000.0000.0001 1 2 20 15 port-channel1
VLAN0300 24876 0000.0000.0001 1 2 20 15 port-channel1
VLAN0320 24896 0000.0000.0001 1 2 20 15 port-channel1
VLAN0321 24879 0000.0000.0001 1 2 20 15 port-channel1
VLAN0400 24976 0000.0000.0001 1 2 20 15 port-channel1
VLAN0401 24977 0000.0000.0001 1 2 20 15 port-channel1
On nx5k_b (Operational Secodary) : the output of the "show spanning-tree root" command display
Root Hello Max Fwd
VLAN0001 24577 0000.0000.0001 1 2 20 15 port-channel10
VLAN080 24656 0000.0000.0001 1 2 20 15 port-channel10
VLAN088 24664 0000.0000.0001 1 2 20 15 port-channel10
VLAN0120 24696 0000.0000.0001 1 2 20 15 port-channel10
VLAN0122 24698 0000.0000.0001 1 2 20 15 port-channel10
VLAN0124 24700 0000.0000.0001 1 2 20 15 port-channel10
VLAN0126 24702 0000.0000.0001 1 2 20 15 port-channel10
VLAN0128 24704 0000.0000.0001 1 2 20 15 port-channel10
VLAN0140 24716 0000.0000.0001 1 2 20 15 port-channel10
VLAN0141 24717 0000.0000.0001 1 2 20 15 port-channel10
VLAN0150 24726 0000.0000.0001 1 2 20 15 port-channel10
VLAN0300 24876 0000.0000.0001 1 2 20 15 port-channel10
VLAN0320 24896 0000.0000.0001 1 2 20 15 port-channel10
VLAN0321 24879 0000.0000.0001 1 2 20 15 port-channel10
VLAN0400 24976 0000.0000.0001 1 2 20 15 port-channel10
VLAN0401 24977 0000.0000.0001 1 2 20 15 port-channel10
12-09-2020 01:22 PM
No attachment
12-09-2020 01:30 PM
just re-attached it.
12-09-2020 02:00 PM
what is the end device? Windows Server how is the configuration on the Server.
If this is orphan ports, based on the Server side config it will decide which port to use to send traffic. again this based on the information provided here.
please post the connected (where the end servers) port configuration information? is this trunk with an access port or many VLAN passing here?
when you want to be orphan port here, is the server not support LACP and vPC should solve many issues. (you have the best technology you need to take advantage of that) - until you have any reason to deploy this please explain.
12-09-2020 02:11 PM
I just revised the diagram.
The device attached to both vPC peers is an ESXi host
Each link is configured as Trunk port with several VLANs allowed on the trunk
No LACP used. This was decided by the system/vmware team (orphan ports)
12-09-2020 02:42 PM
Ok, i have a closed look at the diagram here - upper side (north is VSS). and the only vPC on 5K here.
1. your HSRP where active will be decided here to reach the path in best way in Layer 2 based on root port of spanning tree
if the network relies on STP then the process same for the election path method of old school of STP.
can you post both the nexus spanning-tree output?
12-09-2020 03:12 PM
Apologies. I revised the diagram, again!
Since we are using VSS, there no HSRP. The default GW for VLAN120 is 10.1.120.1.
Here's the output from the spanning-tree vlan 120 command from both 5Ks:
5K_a#
sh spanning-tree vl 120
VLAN0120
Spanning tree enabled protocol rstp
Root ID Priority 24696
Address 0000.0000.0001
Cost 1
Port 4096 (port-channel1)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32888 (priority 32768 sys-id-ext 120)
Address 0000.0000.0003
Interface Role Sts Cost Prio.Nbr Type
Po1 Root FWD 1 128.4096 (vPC) P2p
Po10 Desg FWD 1 128.4105 (vPC peer-link) P2p
Po80 Desg FWD 1 128.4209 (vPC) Edge P2p
Po88 Desg FWD 1 128.4211 (vPC) Edge P2p
Po120 Desg FWD 1 128.4212 (vPC) Edge P2p
Po122 Desg FWD 1 128.4214 (vPC) Edge P2p
Po124 Desg FWD 1 128.4215 (vPC) Edge P2p
5K_b#
VLAN0120
Cost 2
Port 4105 (port-channel10)
Address 0000.0000.0004
Po10 Root FWD 1 128.4105 (vPC peer-link) P2p
Po188 Desg FWD 1 128.4211 (vPC) Edge P2p
