Traffic from WLC to Guest network
ejdrijin1
I have a network were the controller is placed and a guest network. The guest network default gateway is an interface on the Cisco ASA. Even the other network default gateway is the ASA. I have an issue that from the guest network I can still access the controller.
I have created access lists on the ASA to deny traffic from the controller to the guest network but still I can see the login page.
Also to make sure that there is not any other routes I shut down the Interface of the Guest network on the ASA the controller is not reachable.
Any ideas why this is happening even when I blocked all traffic to the guest network? Or else is there a way which I can troubleshoot it or monitor traffic?
Thanks.
Hello
Have you create the guest vlan on the switch and ssid/vlan on the wlc?
What security method and authentication have you used?
res
Paul
Kind Regards
Paul
Thanks for your reply.
Yes i created on both switch and controller.
Security method for guest users you mean? Psk
Thanks.
