Traffic loss power supply related?
Ton V Engelen
Level 3
Level 3
we ran into a very weird issue
Setup: two 6513-E core switches running VSS, both have two power supplies
We ve had some power issues regarding one power supply. So had it replaced but still seeing some issues
At a certain point all kind of traffic got lost yet we could not find anything causing this
Untill we shut down one of the two power supplies on one 66513-E, everything went back to normal.
Huh? Well, yes.
As i could not really believe it, i turned it back on a week later.
Result, traffic gets lost again
Turn off power, everything went to normal.
Anyone has a clue?
The power supply was replaced once already, could this be a chassis issue?
FW: s2t54-advipservicesk9_npe-mz.SPA.151-2.SY5.bin
For whats its worth, there s nothing in the logging, nothing to see reagding power supplies etc
Thanks in advance
Reza Sharifi
I would suspect this a software bug that is causing this. You may want to open a ticket with TAC and see if they recommend a different version of IOS. Very strange.
Reza Sharifi
yeah its like water burning...
ok, i will do that, thank you!
sure. Let us know what you find out.  I can understand if one power supply could not handle the chassis load but in your case, the problem appears when you turn on 2 power supplies.
Good Luck!
