Traffic Shapping on 881 Vlan switch , on the dialer interface
shivaleelag
Hi There ,
I am trying to apply policy shaping on dialer interface , but seems shaping has no effect.
I tried to apply polic-map on vlan 1 , but get error as " configuration-failed!! "
When applied on Fa0 , qos has no effect
when policy-map is applied on dialer interface , queing does happens but shaper does not work,
881#sh version
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.1(4)M5, RELEASE SOFTWARE (fc1)
class-map match-all BestEffort
match ip dscp default
class-map match-all RealTime1
match ip dscp ef
class-map match-any Application1
match ip dscp af43
policy-map Child-1
class Application1
  bandwidth percent 20
class RealTime1
  police cir 296000
   conform-action transmit
   exceed-action drop
   violate-action drop
class class-default
policy-map Parent-1
class class-default
  shape average 22000000
  service-policy Child-1
interface FastEthernet0
description ### ADSL WAN PHYSICAL ###
no ip address
no cdp enable
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
switchport access vlan 12
no ip address
duplex full
speed 100
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
ip virtual-reassembly in
pppoe-client dial-pool-number 1
interface Vlan12
ip address 5.5.5.1 255.255.255.0
no ip redirects
ip nat inside
interface Dialer1
description BT PPPoE Link
mtu 1492
bandwidth 10000000
bandwidth inherit
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
load-interval 30
dialer pool 1
dialer idle-timeout 0
dialer-group 1
ppp authentication callin
ppp chap hostname xxxx
ppp chap password xxxx
ppp pap sent-username xxxx password xxxx
ppp ipcp route default
no cdp enable
service-policy output Parent-1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 10 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 10 permit 5.5.5.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
end
881#show policy-map in di 1
Dialer1
  Service-policy output: Parent-1
Class-map: class-default (match-any)
   17411686 packets, 9183008120 bytes
   30 second offered rate 23142000 bps, drop rate 0 bps -------->I am sending 23Mbps and drop rate is 0 whereas shaper is set to 22Mbps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 0/0
      shape (average) cir 22000000, bc 88000, be 88000
      target shape rate 22000000
      Service-policy : Child-1
        Class-map: Application1 (match-any)
          0 packets, 0 bytes
          30 second offered rate 0 bps, drop rate 0 bps
          Match: ip dscp af43 (38)
            0 packets, 0 bytes
            30 second rate 0 bps
          Queueing
          bandwidth 20% (4400 kbps)
        Class-map: RealTime1 (match-all)
          0 packets, 0 bytes
          Match: ip dscp ef (46)
          Queueing
          police:
              cir 296000 bps, bc 9250 bytes, be 9250 bytes
            conformed 0 packets, 0 bytes; actions:
              transmit
            exceeded 0 packets, 0 bytes; actions:
              drop
            violated 0 packets, 0 bytes; actions:
              drop
            conformed 0 bps, exceed 0 bps, violate 0 bps
          17411612 packets, 9182955740 bytes
          30 second offered rate 23144000 bps, drop rate 0 bps
          Match: any
Any suggestions really appreciated..
Best Rgds
Shiv
7 Replies 7
Can you please provide following outputs :
show ip int brief
show run int virtual-access <# seen from above output>
Complete 'show policy-map interface' output.
H. Pabla
Hi Pabla,
Here is the output.
BLab-881#show ip int brief
Any interface listed with OK? value "NO" does not have a valid configuration
Interface                  IP-Address      OK? Method Status                Protocol
Dialer1                    80.193.254.214  YES IPCP   up                    up
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  down                  down
FastEthernet2              unassigned      YES unset  down                  down
FastEthernet3              unassigned      YES unset  up                    up
FastEthernet4              unassigned      YES NVRAM  administratively down down
NVI0                       unassigned      NO  unset  up                    up
Virtual-Access1            unassigned      YES unset  up                    up
Vlan1                      unassigned      YES manual up                    up
Vlan12                     5.5.5.1         YES manual up                    up
BLab-881#show running-config interface virtual-access 1
Building configuration...
Current configuration : 140 bytes
interface Virtual-Access1
mtu 1492
bandwidth 10000000
no ip address
ip nat outside
pulse-time 0
end
BLab-881#show po
BLab-881#show policy-map int
BLab-881#show policy-map interface
Dialer1
      21294313 packets, 11230863518 bytes
      30 second offered rate 23292000 bps, drop rate 0 bps
      Match: any
      Queueing
          0 packets, 0 bytes
            0 packets, 0 bytes
          Queueing
          0 packets, 0 bytes
          Queueing
          police:
              transmit
              drop
              drop
          21294240 packets, 11230813060 bytes
          Match: any
Virtual-Access1
      1969 packets, 1640906 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: any
      Queueing
          0 packets, 0 bytes
            0 packets, 0 bytes
            5 minute rate 0 bps
          Queueing
          0 packets, 0 bytes
          Queueing
          police:
              transmit
              drop
              drop
          Match: any
Also, you might want to see
http://www.cisco.com/en/US/docs/ios-xml/ios/qos_conavd/configuration/15-mt/qos-conavd-dial.html
Shaping on dialer was introduced from 15.3(1)T
Hi Harsimrandeep,
Thank you so much for the reply. I will try to upgrae to 15.3 and retest.
I hope there is no issue with configs.
Between how about 887 ?  I did see the same behaviour on 887 .
Best Regads
Shiva
Lets first upgrade the code, if issue is not resolved, we will revisit to configs.
Its not a platform issue, same behavior will be seen on all ISR-G2 routers.
Pabla
Hi Pabla,
I upgraded to 15.3 and still the same
BLab-881# sh version
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.3(2)T, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 28-Mar-13 13:08 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
BLab-881 uptime is 40 minutes
System returned to ROM by reload at 10:18:48 UTC Fri Jun 28 2013
System image file is "flash:c880data-universalk9-mz.153-2.T.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
BLab-881#sh ip int bri
BLab-881#sh ip int brief
Dialer1                    80.193.254.215  YES IPCP   up                    up
NVI0                       unassigned      YES unset  administratively down down
Vlan1                      unassigned      YES unset  up                    up
Vlan12                     5.5.5.1         YES NVRAM  up                    up
BLab-881#sh policy-map int
Dialer1
      6148467 packets, 3228677284 bytes
      30 second offered rate 19600000 bps, drop rate 0000 bps
      Match: any
      Queueing
      shape (average) cir 18000000, bc 72000, be 72000
      target shape rate 18000000
          0 packets, 0 bytes
          30 second offered rate 0000 bps, drop rate 0000 bps
            0 packets, 0 bytes
          Queueing
          bandwidth 20% (3600 kbps)
          0 packets, 0 bytes
          Queueing
          police:
              transmit
              drop
              drop
            conformed 0000 bps, exceeded 0000 bps, violated 0000 bps
          6148469 packets, 3228678658 bytes
          Match: any
where as policy-map is set to 18Mbps
Best Regards
Shiva
Hi Pabla,
Its working fine now.Qos with shaper and policer.
Little research on 881 releaved that we need to use F4 interface which is WAN interface in 881.
So the corrected config is:
no ip address
pppoe enable
no cdp enable
interface Vlan1
no ip address
Thank  you so much for your time.
Best Regards
Shivaleela
