Transmitting and receiving frame counts
michael.luo
Let say, node A was sending data  to node B on Ethernet.
On node A, will the transmitting and receiving frame counts pretty much the same?  Or the transmitting frame count should be much larger than receiving count?
Thanks!
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Much depends on the protocol being used.
For example, if TCP is being used, TCP will usually ACK every other received packet.  I.e. On node A, transmitted to received counts would be about 2:1.
Joseph W. Doherty
Disclaimer
Posting
Yes, TCP was used.  So it's approximately 2:1?
Yes, for TCP from just A to B.
