Trouble connecting Cisco router with cable modem for Internet purposes
msomerville99
So I am requesting help from the Cisco community on this issue as the cable company states there equipment is working fine.  At all my facilities I have a guest Internet service setup through a local Internet provide to provide Internet services to the residents and guests.  I have the cable modem usually a Motorola SBG6580 or a SMC 8014 (both provided by cable company) connected to my router on a FE or GE interface.  I am using static IPs and using the cable modem just as a modem (bridge mode).  Over the past several months these connections have just stopped working.  I have not made any drastic changes to my router configs; however, the cable company has updated the firmware on these modems.  I am wondering if that could affected how the modem and router talk.  I was told by the cable company that the modem sees the Cisco router but that the port is inactive.  My router shows the port is active and traffic passing.  Does anyone have any ideas that could point where the problem lies?  I will post a basic config to one that currently does not work.  I am using a VRF to route a certain group out, using NAT.  Please let me know if I need to post additional info.  Any help would be greatly appreciated.
Cisco CISCO2911/K9
Version 15.2(3)T1
service timestamps debug datetime localtime
service timestamps log datetime localtime show-timezone
service password-encryption
hostname 1204RTR01
boot-start-marker
boot system flash0:c2900-universalk9-mz.SPA.152-3.T1.bin
boot system flash0:c2900-universalk9-mz.SPA.151-3.T.bin
boot-end-marker
card type t1 0 0
logging buffered 64000
aaa new-model
aaa session-id common
clock timezone cst -6 0
clock summer-time CDT recurring
no ipv6 cef
no ip source-route
ip vrf 5
 rd 5:1
ip multicast-routing
ip dhcp pool Guest
 vrf 5
 network 10.51.XXX.0 255.255.255.0
 default-router 10.51.XXX.XXX
 dns-server 209.18.47.61 209.18.47.62
ip flow-cache timeout active 1
no ip bootp server
no ip domain lookup
ip cef
application
 global
  service alternate default
license udi pid CISCO2911/K9 sn FTX1508AHTM
hw-module pvdm 0/0
redundancy
ip tcp synwait-time 10
interface GigabitEthernet0/0.5
 description Guest VLAN
 encapsulation dot1Q 5
 ip vrf forwarding 5
 ip address 10.51.xx.xxx 255.255.255.0
 no ip redirects
 no ip proxy-arp
 ip nat inside
 ip virtual-reassembly in
 ip tcp adjust-mss 1452
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/2
 description Guest Intenet access
 ip vrf forwarding 5
 ip address 24.242.182.182 255.255.255.252   <--Cable company IP, Modem IP is 24.242.182.181
 ip nat outside
 load-interval 30
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 9 interface GigabitEthernet0/2 vrf 5 overload
ip route vrf 5 0.0.0.0 0.0.0.0 24.242.182.181
access-list 9 permit 10.51.204.0 0.0.0.255
13 Replies 13
mfurnival
Level 4
Level 4
Probably you have tried these things but I will ask the questions anyway:
1. Can you ping  24.242.182.181 from the router?
2. Can you ping 8.8.8.8 from the router?
3. Can you enable "debug ip nat trans" on the router - do you see any nat translations taking place?
Your comment " I was told by the cable company that the modem sees the Cisco router but that the port is inactive" confused me a bit - how can it see the Cisco if the port is inactive? Do they mean 0 packets in and out?
Cannot ping 24.242.182.181 through the vrf.  cannot ping 8.8.8.8 through the vrf
I have about 30 locations with the exact same setup.  Only 8 are not working.  All the routers are 2901, 2911s running the same IOS.  The modems are Motorola or SMC modems.  The cable company said they see the router but shows inactive.  I am puzzled too with the inactive part because the cable company will not let me log into the modem and look for myself.
Does G0/2 show packets in and out of you do a "show interface G0/2"? Are you able to resolve the mac address of 24.242.182.181 (show arp | i 24.242.182.181)? I notice you have speed and duplex set to auto - have you tried hard setting them?
Ok, mysteriously this location just started working yesterday, but I still am dealing with seven others and I really would like to know what is going on.  I will give you everything you may need and let me know.
Config:
version 15.2
no service pad
hostname 1112RTR01
boot-start-marker
boot system flash0:c2900-universalk9-mz.SPA.151-1.T.bin
boot-end-marker
aaa new-model
clock timezone CDT -6 0
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
no ipv6 cef
no ip source-route
ip vrf GuestVRF
 rd 5:1
ip dhcp pool Guest
 vrf GuestVRF
 network 10.51.112.0 255.255.255.0
 default-router 10.51.112.1
no ip bootp server
no ip domain lookup
ip cef
application
 global
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
 ip vrf forwarding GuestVRF
 ip address 10.51.112.1 255.255.255.0
 no ip redirects
 no ip proxy-arp
 ip nat inside
 description Guest Internet (Time Warner Connection)
 ip address 97.77.116.234 255.255.255.252
 ip nat outside
 load-interval 30
 duplex auto
 speed auto
ip nat inside source list 5 interface GigabitEthernet0/1 vrf GuestVRF overload
ip route vrf GuestVRF 0.0.0.0 0.0.0.0 97.77.116.233
access-list 5 permit 10.51.112.0 0.0.0.255
control-plane
end
router#sh ip arp vrf GuestVRF
router#Internet  97.77.116.233           2   f80b.bee7.e09f  ARPA   GigabitEthernet0/1
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  97.77.116.234           -   8843.e13c.8d99  ARPA   GigabitEthernet0/1
router#ping vrf GuestVRF 97.77.116.233
Sending 5, 100-byte ICMP Echos to 97.77.116.233, timeout is 2 seconds:
Success rate is 0 percent (0/5)
router#sh int g0/1
GigabitEthernet0/1 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is 8843.e13c.8d99 (bia 8843.e13c.8d99)
  Description: Guest Internet (Time Warner Connection)
  Internet address is 97.77.116.234/30
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full Duplex, 1Gbps, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:00:10
  Input queue: 76/75/15/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 3000 bits/sec, 7 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
     81 packets input, 4860 bytes, 0 no buffer
     Received 81 broadcasts (0 IP multicasts)
     0 runts, 0 giants, 12 throttles
     0 watchdog, 0 multicast, 0 pause input
     16 packets output, 1193 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
router#sh int g0/1
  Last clearing of "show interface" counters 00:00:42
  Input queue: 76/75/67/0 (size/max/drops/flushes); Total output drops: 0
  30 second output rate 1000 bits/sec, 2 packets/sec
     408 packets input, 24480 bytes, 0 no buffer
     Received 408 broadcasts (0 IP multicasts)
     0 runts, 0 giants, 61 throttles
     72 packets output, 5669 bytes, 0 underruns
I am receiving packets in and out of the interface but I cannot ping the modem through the VRF.
router#sh ip nat translations
Pro Inside global      Inside local       Outside local      Outside global
udp 97.77.116.234:3169 10.51.112.39:3169  209.18.47.62:53    209.18.47.62:53
udp 97.77.116.234:8534 10.51.112.39:8534  209.18.47.61:53    209.18.47.61:53
udp 97.77.116.234:12244 10.51.112.39:12244 209.18.47.61:53   209.18.47.61:53
udp 97.77.116.234:14002 10.51.112.39:14002 209.18.47.61:53   209.18.47.61:53
udp 97.77.116.234:23623 10.51.112.39:23623 209.18.47.62:53   209.18.47.62:53
udp 97.77.116.234:24489 10.51.112.39:24489 209.18.47.61:53   209.18.47.61:53
udp 97.77.116.234:24550 10.51.112.39:24550 209.18.47.61:53   209.18.47.61:53
udp 97.77.116.234:27458 10.51.112.39:27458 209.18.47.62:53   209.18.47.62:53
udp 97.77.116.234:28603 10.51.112.39:28603 209.18.47.62:53   209.18.47.62:53
udp 97.77.116.234:37404 10.51.112.39:37404 209.18.47.62:53   209.18.47.62:53
udp 97.77.116.234:53942 10.51.112.39:53942 209.18.47.61:53   209.18.47.61:53
udp 97.77.116.234:58125 10.51.112.39:58125 209.18.47.62:53   209.18.47.62:53
udp 97.77.116.234:64797 10.51.112.39:64797 209.18.47.61:53   209.18.47.61:53
udp 97.77.116.234:56925 10.51.112.52:56925 209.18.47.61:53   209.18.47.61:53
udp 97.77.116.234:56925 10.51.112.52:56925 209.18.47.62:53   209.18.47.62:53
udp 97.77.116.234:62342 10.51.112.52:62342 209.18.47.62:53   209.18.47.62:53
tcp 97.77.116.234:36559 10.51.112.69:36559 199.167.177.46:1227 199.167.177.46:1227
tcp 97.77.116.234:48895 10.51.112.69:48895 54.195.253.126:5223 54.195.253.126:5223
tcp 97.77.116.234:58385 10.51.112.69:58385 54.195.243.137:5223 54.195.243.137:5223
tcp 97.77.116.234:58658 10.51.112.71:58658 31.13.66.165:443  31.13.66.165:443
udp 97.77.116.234:3066 10.51.112.72:3066  209.18.47.62:53    209.18.47.62:53
udp 97.77.116.234:3884 10.51.112.72:3884  209.18.47.61:53    209.18.47.61:53
udp 97.77.116.234:6656 10.51.112.72:6656  209.18.47.61:53    209.18.47.61:53
udp 97.77.116.234:11194 10.51.112.72:11194 209.18.47.61:53   209.18.47.61:53
udp 97.77.116.234:11774 10.51.112.72:11774 209.18.47.62:53   209.18.47.62:53
Let me know if you need anything else.  I need to figure this out and I just don't get it because the other site wasn't working a few days ago and all of a sudden it is working again but others are still not.
Any resolution on this?
Having the exact same issue with CableOne Internet provider in Mississippi.  Using a Motorola SurfBoard modem with a Cisco 2911 router.
The gigabit port refuses to turn up/negotiate with the Motorola modem.
No, the cable providers here will not accept any responsibility.  I am going to have to open a case with Cisco and see if I can what they say.
You didn't answer my questions:
I show packets coming in and out but I can't ping the modem.  The modem according to the cable company sees the router mac but shows the port to be inactive.   The router shows the mac of the modem.  It started working for a few days and then it stopped again.  yes, I have tried hard coding them.  That did not work.
For what it's worth, after complaining to the cable company enough they replaced our Motorola Modem with an Arris Modem and the problem stopped.  Everything is working as it should.
Lucas Phelps
Level 5
Level 5
Lucas,
   When did this start happening to your site?  The reason I am asking is I think it may have to do with the latest firmware upgrade on the modem.  I have some 2911s that are working with the motorola and others that are not but with different firmware versions on the modem/router itself.
Brian Tissue
In that past with several different types of modems/ISPs I had to spoof the mac address of the outside interface to get traffic moving.
Your NAT translations and general config look good.
Try this on your outside interface.
mac-address 0017.3f7f.ad35
