3750X QoS Not Working
DJX995
Level 3
Level 3
I can't seem to get my 3750X to mark DSCP values.
I am testing with HTTP from a server on another VLAN.
Using WireShark, the HTTP packets are all marked 0.
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.2(1)E3, RELEASE SOFTWARE (fc1)
QoS is enabled
QoS ip packet dscp rewrite is enabled
Extended IP access list QoS-ACL-Ceton-InfiniTV-Data
    10 permit udp any any range 5001 5016
Extended IP access list QoS-ACL-Ceton-InfiniTV-Signaling
    10 permit tcp any any eq 554
    20 permit udp any any range 5757 5772
    30 permit tcp any any eq www
Class Map match-all QoS-Ceton-InfiniTV-Signaling-Class (id 9)
   Match access-group name QoS-ACL-Ceton-InfiniTV-Signaling
 Class Map match-all QoS-Ceton-InfiniTV-Data-Class (id 10)
   Match access-group name QoS-ACL-Ceton-InfiniTV-Data
  Policy Map QoS-Ceton-InfiniTV-Policy
    Class QoS-Ceton-InfiniTV-Data-Class
      set dscp af41
    Class QoS-Ceton-InfiniTV-Signaling-Class
      set dscp af21
interface GigabitEthernet1/0/36
 description VLAN 100 - Ceton InfiniTV 6 ETH
 switchport access vlan 100
 switchport mode access
 ipv6 nd raguard
 spanning-tree portfast
 service-policy input QoS-Ceton-InfiniTV-Policy
end
Any suggestions?
Thanks.
acampbell
I think the issue you are seeing is being caused by
your access list
    30 permit tcp any any eq www   ?????
The service policy is inbound from your http (www) server
So you need to match the packets from the server as WWW
Try this
no Extended IP access list QoS-ACL-Ceton-InfiniTV-Signaling
    30 permit tcp any eq www any
    40 permit tcp any eq 443 any
Hope this helps
Alex
Regards, Alex. Please rate useful posts.
acampbell
your access list
Try this
Hope this helps
Alex
I will try that soon. The device that I applied the policy to (Gig1/0/36) has all these services. I'm just trying to access the web deamon (http) from a machine (happens to be a server) on another vlan to check the DSCP values. Hope that makes things a little clearer. I just copied the same formating from the auto QoS policies that the switch generated. In those policies, the ACLs are all: permit proto any any eq port. Thanks.
The just to clear up the ACL format.
permit/deny | protocol | source address | source port | dest address | dest port
So in you case the server will be responding with a source PORT of 80 (www-http) or 443 (HTTPS)
To match this we can use
If it was a end users PC etc we were matching then we move the 80/443 to the destination PORT
permit tcp any any eq 443
Hope this helps
Alex
Thanks Alex.
ACLs and direction always confuses me.
To me, it always seems like it should be the other way.
I always write them backwards.
Anyway,
I tested the HTTP daemon on the Ceton from another machine and verified with Wireshark.
Packets are marked correctly.
I worked out (through trial and error) the rest of the ACL.
Here is my current (working) QoS-ACL:
ip access-list extended QoS-ACL-Ceton-InfiniTV-Data
 permit udp any any range 8000 8015
ip access-list extended QoS-ACL-Ceton-InfiniTV-Signaling
 permit tcp any eq 554 any
 permit udp any range 5757 5772 any
 permit tcp any eq 8554 any
