troubles setting up Vlan with 2 switches
flora.giannone1
Hi Guys
I need to create a vlan  "2303" with these specifics in Solaris:
FIRST SWITCH:
  • create vlan N2303
  • configure "N2303" tag 2303
  • configure "N2303" add port 1 tagged
  • configure "N2303" add port 3 tagged
  • configure "N2303" add port 21 tagged
SECOND SWITCH:
  • create vlan N2303
  • configure "N2303" add port 4 tagged
  • configure "N2303" add port 2 tagged
The configuration of this vlan on the first switch is :
#show vlan id 2303
VLAN Name                             Status    Ports
2303 2303                             active    Gi1/0/1, Gi1/0/3, Gi1/0/21
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
2303 enet  102303     1500  -      -      -        -    -        0      0
Remote SPAN VLAN
Disabled
Primary Secondary Type              Ports
Vlan2303 is up, line protocol is up
  Hardware is EtherSVI, address is 3c5e.c332.e242 (bia 3c5e.c332.e242)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not supported
  Last input 00:03:27, output 01:37:21, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     19617 packets input, 1386644 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     18 packets output, 1692 bytes, 0 underruns
     0 output errors, 2 interface resets
FastEthernet0 is administratively down, line protocol is down
  Hardware is PowerPC FastEthernet, address is 3c5e.c332.e237 (bia 3c5e.c332.e237)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive not set
  Auto-duplex, Auto Speed, MII
  Last input never, output never, output hang never
  Last clearing of "show interface" counters neverInput queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
  Output queue: 0/0 (size/max)
     0 packets input, 0 bytes
     0 watchdog
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 lost carrier, 0 no carrier
#show interface GigabitEthernet1/0/1 trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi1/0/1     on               802.1q         trunking      2303
Port        Vlans allowed on trunk
Gi1/0/1     2303
Port        Vlans allowed and active in management domain
Gi1/0/1     2303
Port        Vlans in spanning tree forwarding state and not pruned
Gi1/0/1     2303
#sh run
Building configuration...
Current configuration : 3658 bytes
version 12.2
service config
no service pad
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c2960s-24ts-l
ip domain-name
vtp mode transparent
spanning-tree mode pvst
no spanning-tree vlan 1-3000
vlan internal allocation policy ascending
vlan 126
vlan 2303
 name 2303
ip ssh version 1
interface FastEthernet0
 no ip address
 shutdown
 switchport access vlan 2303
 switchport trunk native vlan 2303
 switchport trunk allowed vlan 2303
 switchport mode trunk
 switchport nonegotiate
 spanning-tree portfast
 spanning-tree bpduguard disable
interface GigabitEthernet1/0/2
 switchport mode access
 spanning-tree guard none
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
 switchport access vlan 126
interface GigabitEthernet1/0/24
interface Vlan1
 no ip address
 shutdown
interface Vlan126
 ip address 10.16.126.26 255.255.254.0
interface Vlan2303
 no ip address
ip http server
ip http secure-server
line con 0
line vty 0 4
On the second switch:
#show vlan id 2303
2303 VLAN2303                         active    Gi1/0/1, Gi1/0/2, Gi1/0/3, Gi1/0/4, Gi1/0/21
Remote SPAN VLAN
Disabled
  Hardware is EtherSVI, address is 547c.69dd.d142 (bia 547c.69dd.d142)
  Last input 00:00:36, output 01:39:30, output hang never
     21454 packets input, 1470272 bytes, 0 no buffer
     2051 packets output, 132260 bytes, 0 underruns
     0 output errors, 1 interface resets
On the first machine, connected to the switch, i created a vlan
#dladm create-vlan -l net1 -v 2303 vlan1
# ifconfig vlan1 plumb 10.0.0.1/24 up
second machine:
# ifconfig vlan1 plumb 10.0.0.2/24 up
Unfortunately, if i try to ping 10.0.0.2, it doesn't work:
# ping -s 10.0.0.2
PING 10.0.0.3: 56 data bytes
Have i missed something in the configuration on the vlan2303?
Cheeeers
Markus Benz
Hi Flora,
it is difficult to understand what the physical topology is from what you write.
But here is what you should look at:
  • It looks like you configure the vlan 2303 as tagged on the solaris side and native on the cisco side. Try to configure it as either tagged or native on both sides.
  • How many physical links do you have between the server and the switches?
    If there are multiple connections, are the teaming configurations correct? Or is there maybe a port-channel config missing?
Markus
