Troubleshoot faulty switchport
RMS3
I have a C9200L-48P switch with 4x1G uplink module.
Port Gi1/1/1 does not have an LED blinking when connected to another switch.
Ports Gi1/1/2-4 seem to work fine.
Could anyone please guide me on troubleshooting the port and also advise action?
2 Accepted Solutions
"media type is 1000BaseLX SFP"
Are you using a single-mode cable since the optic is single-mode?
If yes, you may want to upgrade to a different version and if that does not solve the problem, you may need to RMA the switch.
Currently I have SFP modules plugged in. The same SFP module and FO Cable is working fine on port Gi1/1/2.
If the SFP Module and Obtic cable working on other ports, may be chances are port gone bad, to confirm that loop the SPF port using single patch cable, see is the port come up ?  if not ?
last is raise TAC case (if hardware issue replace it)
BB
5 Replies 5
Leo Laohoo
Loop Gi1/1/1 to itself.  Does the port go into error disable or does it stay down/down?
balaji.bandi
These are the fixed uplink modules, what kind of SFP is this  Fiber or Copper ? (both supported in this case?)
change the SFP and test it, change the cable and test it. if the Fibre give a Loop and test it.
also post show interface gig 1/1/1 output here?
what IOS XE running on this switch ?
BB
Hi @balaji.bandi ,
Thanks for the response.
The switch is running on 17.9.4a.
Output of show interface:
sh int gi1/1/1
GigabitEthernet1/1/1 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 648f.3e30.61b1 (bia 648f.3e30.61b1)
Description: MUX B
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLX SFP
input flow-control is on, output flow-control is unsupported
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
Output 0 broadcasts (0 multicasts)
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
BB
