Troubleshooting Input queue drops and Overruns
burleyman
Level 11
Level 11
What should I look at for the two things shown....Input Queue drops and Overruns. see output below.
GigabitEthernet1/23 is up, line protocol is up (connected)
Hardware is xxxxxx
Description: xxxxxx
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s
input flow-control is off, output flow-control is off
Clock mode is auto
Last input never, output 00:00:05, output hang never
Last clearing of "show interface" counters 03:09:23
Input queue: 0/2000/92/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 233000 bits/sec, 49 packets/sec
5 minute output rate 2647000 bits/sec, 415 packets/sec
737496 packets input, 433114351 bytes, 0 no buffer
Received 11544 broadcasts (11350 multicasts)
0 input errors, 0 CRC, 0 frame, 46 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
5911353 packets output, 5099556374 bytes, 0 underruns
Thank you
Mike
sachinraja
Level 11
Level 11
Hello Mike,
You basically need to look if the server connected to this NIC, is sending more / burst data which the switchport is not able to manage.. Overruns are caused due to this.. if the switch does not have the packet buffer and memory to accumulate long bursts of data, these kind of errors occur.. it can also be due to a software defect.. check with the release notes of the software u are running...
Check if you can do some analysis on the server side... also see if u can upgrade the software, if any caveats !!!!
Hope this helps.. all the best..
Raj
Hello Mike,
Any luck with this ?? Did you check ? DO let us know.
Raj
rpsunbeam
Level 2
Level 2
what kind of card is this on?
certain of the 48 port gig 6500 blades will not do wire speed.. very bad news if you have servers on them.
actually, after looking at your numbers... you had 6 million packets input/output and umm 138 errors? you have a 0.0023 percent drop rate.. I wouldn't worry about that at all.
