Troubleshooting LAN/WAN problems
marcospce
Community Member
Hey guys,
What informations are important in a sh interface (port) command to troubleshoot a problem ?
What i have to look ? What is the normal and problematic numbers ?
allan.thomas
Level 11
Level 11
There are four aspects which I would initially be aware of when troubleshooting an interface, these are as follows:
Verify that the Line and Protocol status are both UP.
Verify that the Reliability is 255/255, any thing less would indicate a physical issue.
Verify that the a LAN interface for example is operating at the correct speed and duplex.
Ensure that there are not errors occuring, such as CRC, collisions/multiple collisions, and packet drops.
Hope this helps
Allan.
Kevin Dorrell
Level 11
Level 11
If it is a serial line, here is a good document that tells you about the command:
http://www.cisco.com/univercd/cc/td/doc/cisintwk/itg_v1/tr1915.htm
If it is a switch port, this is the document:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfd6.shtml
Hope this helps.
Kevin Dorrell
Luxembourg
