troubleshooting menu 9200l not shown
cisco77009350
hi, i use a cisco Sw 9200l 24p-4g. I can't use the troubleshooting menu because the sub menus not shown.
the picture attached. please help me. IOS XE 17.13.1 and IOS XE 17.15.1 tested.
16 Replies 16
add privilege 15 to user in cli
MHM
show privilege
Current privilege level is 15
share http config of WLC
MHM
#show configuration
Using 5639 out of 2097152 bytes
! Last configuration change at 14:30:28 IRST Mon Nov 25 2024 by master
! NVRAM config last updated at 14:47:44 IRST Mon Nov 25 2024 by master
version 17.13
service call-home
platform punt-keepalive disable-kernel-core
hostname test
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
clock timezone IRST 3 30
boot system switch all flash:packages.conf
switch 1 provision c9200l-24p-4g
ip domain name master
login on-success log
crypto pki trustpoint TP-self-signed-412578570
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-412578570
revocation-check none
rsakeypair TP-self-signed-412578570
hash sha256
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
hash sha256
crypto pki certificate chain TP-self-signed-412578570
certificate self-signed 01 nvram:IOS-Self-Sig#2.cer
crypto pki certificate chain SLA-TrustPoint
certificate ca 01 nvram:CiscoLicensi#1CA.cer
license boot level network-essentials addon dna-essentials
memory free low-watermark processor 10623
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
enable secret 9 $9$WvX6rg8zm.svL.**************
username master privilege 15 secret 8 $8$HyDVP5ogT2OHO.**********************
redundancy
mode sso
transceiver type all
monitoring
class-map match-any system-cpp-police-ewlc-control
description EWLC Control
class-map match-any system-cpp-police-topology-control
description Topology control
class-map match-any system-cpp-police-sw-forward
description Sw forwarding, L2 LVX data packets, LOGGING, Transit Traffic
class-map match-any system-cpp-default
description EWLC data, Inter FED Traffic
class-map match-any system-cpp-police-sys-data
description Openflow, Exception, EGR Exception, NFL Sampled Data, RPF Failed
class-map match-any system-cpp-police-punt-webauth
description Punt Webauth
class-map match-any system-cpp-police-l2lvx-control
description L2 LVX control packets
class-map match-any system-cpp-police-forus
description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
description MCAST END STATION
class-map match-any system-cpp-police-high-rate-app
description High Rate Applications
description MCAST Data
class-map match-any system-cpp-police-l2-control
description L2 control
class-map match-any system-cpp-police-dot1x-auth
description DOT1X Auth
class-map match-any system-cpp-police-data
description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any system-cpp-police-stackwise-virt-control
description Stackwise Virtual OOB
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
description Routing control and Low Latency
class-map match-any system-cpp-police-protocol-snooping
description Protocol snooping
class-map match-any system-cpp-police-dhcp-snooping
description DHCP snooping
class-map match-any system-cpp-police-ios-routing
description L2 control, Topology control, Routing control, Low Latency
class-map match-any system-cpp-police-system-critical
description System Critical and Gold Pkt
class-map match-any system-cpp-police-ios-feature
description ICMPGEN,BROADCAST,ICMP,L2LVXCntrl,ProtoSnoop,PuntWebauth,MCASTData,Transit,DOT1XAuth,Swfwd,LOGGING,L2LVXData,ForusTraffic,ForusARP,McastEndStn,Openflow,Exception,EGRExcption,NflSampled,RpfFailed
policy-map system-cpp-policy
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
shutdown
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface Vlan1
ip address 192.168.1.32 255.255.0.0
ip http server
ip http authentication local
ip http secure-server
ip forward-protocol nd
ip ssh bulk-mode 131072
snmp-server community swmaster RO
snmp-server location test
snmp-server manager
control-plane
service-policy input system-cpp-policy
line con 0
stopbits 1
line vty 0 4
login local
length 0
transport input ssh
line vty 5 15
login local
length 0
transport input ssh
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
ntp server 192.168.1.20
end
Hi Friend
It seem your post have some issue it dissappear
anyway
try add under vty
privilege 15
MHM
oguzhang
Have you trying accessing from different computers , users and different browsers?
Yes, I tried. But the conditions were no different
In looking at the posted config I notice several things, starting with the observation that the IP address configured uses a /16 mask. I don't know that it is a problem, but it is certainly very unusual. I would suggest changing the config so that it uses a more usual /24.
I also note that are not any ip route statements, or any routing protocol configured, or any default-gateway configured. I don't know that this is a problem, but I would suggest that you configure some type of routing logic. (and related to this is a question whether you intend this to operate as a layer 2 device or as a layer 3?)
Rick
hello I haven't decided on how to use the switch yet. I just wanted to access the log menu. In the 9300 model, this menu can be accessed from troubleshooting, but in the 9200 model, this is not possible.
Leo Laohoo
FFS.
Look at the configuration of the ports.  Not even STP portfast.
Try downgrading to 17.12.4.
shambhu.kumar
Hello
I have configured these CLI
ip http server
ip http client source-interface Vlan1
All the sub-menus are showing under troubleshooting, But The IOS-XE are17.06.05 and 17.12.04
17.12.04 is showing different sub-menu under troubleshooting
Am I correct in understanding the original post described a problem where the sub menus were not showing up. And that now, after some config changes, the sub menus are showing up?
Rick
I have tested at my end with 17.06.05 and 17.12.04 in catalyst 9200. Not sure, user  " cisco77009350" is still facing same issue.
I will send you some points to check.
Sorry for late
MHM
