Trunk and Data vlan configuration between cisco 2960 and SG300-20
Ayub
Hi All,
I have one 2960 and one SG-300-20 switch:
- Need to configure trunk ports between them
- Need to configure managment vlan (10) and svi for management vlan on SG-300-20
- Need to configure data vlan (20) and svi for data vlan on cisco SG-300-20
I tried alot but didnt work for me. Please share sample configuration.
Seb Rupik
Hi there,
Try the below config. The trunk link will be between the first port on both switches. I have configured a DHCP pool for VLAN10, so that if you connect a device to Gi1/0/2 on the 2960 you should pick up a lease in the 192.168.10.0/24 subnet.
SG300:
set system mode router
vlan 10
vlan 20
int vlan 10
  ip address 192.168.10.254 255.255.255.0
int vlan 20
  ip address 192.168.20.254 255.255.255.0
int gi0
  description "TRUNK TO 2960"
  switchport trunk allowed vlan add 10,20
ip dhcp server
ip dhcp pool network DHCP_POOL10
  address 192.168.10.0 /24
  default-router 192.168.10.254
  dns-server 1.1.1.1
ip dhcp excluded-address 192.168.10.254
2960:
vlan 10
vlan 20
int gi1/0/1
desc TRUNK_TO_SG300 switchport mode trunk switchport trunk allowed vlan add 10,20 ! int gi1/0/2 switchport mode access switchport access vlan 10 spanning-tree portfast !
cheers,
Seb.
