Trunk between 6500 and 3750.
andrea.meconi
Level 2
Level 2
I'm using a stack of two 3750 (one 3750G-12 and one 3750-48). This stack is connected to a 6500 via a 1000SX link (SFP). This link is a .1Q trunk. If I use a port on the first switch (3750G) I have many input error,
0 runts, 391 giants, 0 throttles
17767355 input errors, 20941 CRC, 0 frame, 0 overrun, 0 ignored
but if I move to a port on the other 3750 no more errors appear!
Any ideas!?
Thanks.
Andrea
7 Replies 7
mahmoodmkl
Level 7
Level 7
Can u paste the config of the devices.
Mahmood
Now I'm using g2/0/2 to connect the stack to the port 4/1 on 6500. Errors appear using g1/0/1.
Thanks.
Andrea
BrinksArgentina
Hi Andrea.
1) This problem ocurr with any port of the 3750G-12?
2) Can you copy the sh int gi1/0/1 please?
3) You use the same SPF adapter?
Guido
Hi Guido.
1) I don't know. I don't have a free port.
Today I'll try to switch with another port on 3750G-12.
2) Sorry, a clear counter command already applied.
C3750-12g-P1#sh int g1/0/1
GigabitEthernet1/0/1 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 000f.8fd6.3181 (bia 000f.8fd6.3181)
Description: Link P1 - Catalyst6500 Pal3B
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive not set
Auto-duplex, Auto-speed, link type is auto, media type is Not Present
Media-type configured as connector
input flow-control is off, output flow-control is unsupported
Last input 3d22h, output 3d22h, output hang never
Last clearing of "show interface" counters 15:26:19
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
3) Yes, I'm moving the SFP to a port on 3750-48 without any errors!
Many thank for your help.
Andrea.
Some IOS allow that "SFP" ports can be set to "full duplex", disabling the "auto-sense." If the other end is set to "auto", you have a duplex mismatch and a lot of errors. Connect the fiber and check if it is full-duplex on both sides or auto on both.
If not, try hardcoding media-type and duplex to auto on both ends or full on both.
Switch(config)#int gi 1/0/1
Switch(config-if)#no media-type
Switch(config-if)#media-type sfp
Switch(config-if)#duplex auto
Guido.
Please rate all the helpful comments.
Hi Guido and many thanks for your help.
Now I'm using g1/0/7 on 3750G-12 without any errors!
May be an damaged ASIC?
I believe I'll replace this switch.
Regards.
Andrea
I have seen a lot of switchs with a failed port, running perfect, but maybe is a good idea move this sw to a lab or keep for backup.
(A client have a 2950 with 5 failed ports but the other 19 work normaly.)
Best regards!
Guido
