Trunk between cisco switch 2960S and 3com switch 5500G
Telecom Tortuga
I am having the problem to do the trunking between cisco switch 2960S and 3com switch 5500G? Seems both of them cannot communicate with each other. Anyone can help?
Males
Can you give us the output of a show interface switchport from both sides?
Which vlans are you trying to pass?
Interface - 3COM 5500G
GigabitEthernet1/0/14 current state : DOWN
IP Sending Frames' Format is PKTFMT_ETHNT_2, Hardware address is 001c-c528-264e
Media type is twisted pair, loopback not set
Port hardware type is 1000_BASE_T
1000Mbps-speed mode, unknown-duplex mode
Link speed type is force link, link duplex type is autonegotiation
Flow-control is not enabled
The Maximum Frame Length is 1522
Broadcast MAX-pps: 3000
Unicast MAX-ratio: 100%
Multicast MAX-ratio: 100%
Forbid jumbo frame to pass
PVID: 1
Mdi type: auto
Port link-type: trunk
  VLAN passing  : 1(default vlan), 2, 18
  VLAN permitted: 1(default vlan), 2, 18
  Trunk port encapsulation: IEEE 802.1q
It belongs to a link-aggregation. It is the master port
Last 300 seconds input:  0 packets/sec 0 bytes/sec
Last 300 seconds output:  0 packets/sec 0 bytes/sec
Input(total):  25703 packets, 5382614 bytes
         3 broadcasts, 79 multicasts, 0 pauses
Input(normal):  - packets, - bytes
         - broadcasts, - multicasts, - pauses
Input:  0 input errors, 0 runts, 0 giants,  - throttles, 0 CRC
         - frame,  - overruns, 0 aborts, - ignored, - parity errors
Output(total): 300023 packets, 20215175 bytes
         51289 broadcasts, 200430 multicasts, 0 pauses
Output(normal): - packets, - bytes
Output: 0 output errors,  - underruns, - buffer failures
         0 aborts, 0 deferred, 0 collisions, 0 late collisions
         0 lost carrier, - no carrier
Interface CISCO 2960S
GigabitEthernet1/0/1 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 04c5.a45d.1381 (bia 04c5.a45d.1381)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 19w2d, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     27601 packets input, 2461188 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     255105 packets output, 16789193 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
I disconnected the cables because I was giving interference in my network, a switch is knocking the port of another switch.
that is no
but we neeed that to see the dot1q config..
Post Shw Run of Int of Cisco and 3com Switch.
Jawad
