Trunk configuration (VTP) between 3750 and 2811
mclavoie
I have a stack of 6 Cisco Catalyst 3750G with 6 VLANs acting as a VTP server and want to establish a trunk link to my Cisco 2811 router equiped with a switching module 16 ports. Can I set the 2811 as a VTP client to propagate the VLAN info from the 3750 and configure one of the port on the switching module of the 2811 as a trunk encapsulated DOT1q and will I be able to route to the outside world.
Thank you
glen.grant
  I beleive the switching cards support vtp and that should be possible.
Table 2. Features Supported on Cisco EtherSwitch Modules
EtherSwitch Network Modules (NM-16ESW and NMD-36ESW)
EtherSwitch HWICs (HWIC-4ESW and HWICD-9ESW)
EtherSwitch Service Modules (NME-16ES-1G, NME-16ES-1G-P, NME-X-23ES-1G, NME-X-23ES-1G-P, NME-XD-48ES-2S-P, and NME-XD-24ES-1S-P)
VLANs
Multiple VLANs per Switch
Yes (varies by chassis; maximum of 64 on Cisco 3845)
Yes (maximum of 15 on any chassis)
Yes (maximum of 1,024 per switch or stack)
VLANs in 4,000 Range
No
No
Yes
IEEE 802.1Q Tagged and Untagged VLANs
Yes
Yes
Yes (802.1Q and Inter-Switch Link [ISL])
VLAN Trunking Protocol (VTP) Support for Client, Server, and Transparent Modes
Yes
Yes
Yes
