Trunk, HWIC and ping issues
mathieu.ploton
I've a tricky issue on a very simple configuration, maybe you can turn my light on it :
I've got this :
(VLAN 1 is the default vlan)
Router 6xxx ===TRUNK===gi0/1 SWITCH L2 fa0/3---VLAN100---- F0/2/0 HWIC 2811
On the 6xxx :
int vlan 100
ip address 192.168.0.1 255.255.255.0
The trunk allow vlan 100.
On the switch L2 :
trunk side:
sh int g0/1 switchport
Switchport: Enabled
Administrative mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: Disabled
Access Mode VLAN: 0 ((Inactive))
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Enabled: ALL
Trunking VLANs Active: 1,3-7,10,11,13,15,18,20,100,101,200,226
Pruning VLANs Enabled: 2-1001
Priority for untagged frames: 0
Override vlan tag priority: FALSE
Voice VLAN: none
Appliance trust: none
Self Loopback: No
fa0/3 side:
interface FastEthernet0/3
duplex full
speed 100
switchport access vlan 100
On the router :
interface Vlan100
ip address 192.168.0.2 255.255.255.0
interface FastEthernet0/2/0
duplex full
speed 100
The issue is that from the 6xxx, I can't ping 192.168.0.2 and from the 2811 i can't ping 192.168.0.1.
When i do a "debug arp" on the 2811 I realized that it has received the arp request from the 6xxx and that it answers it, seems that the answer never end to the 6xxx...
If you have an idea, it drives me nuts...
8 Replies 8
Edison Ortiz
Please post show interface vlan 100 from the 6500 switch.
__
Edison.
sh int vlan 100
Vlan100 is up, line protocol is up
Hardware is Cat6k RP Virtual Ethernet, address is 0008.7ca6.cb02 (bia 0008.7ca6.cb02)
Description: Vlan VoIP
Internet address is 192.168.0.2/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input 00:00:00, output never, output hang never
Queueing strategy: fifo
Output queue :0/40 (size/max)
239414 packets input, 13658122 bytes, 0 no buffer
Received 239312 broadcasts, 0 runts, 0 giants, 0 throttles
2558 packets output, 183906 bytes, 0 underruns
0 output errors, 3 interface resets
Looks good.
1) Let's see show interface gx/x switchport from the 6500 switch.
2) Let's see show vlan from the 6500 and L2 switch and show vlan-switch from the router.
3) In the L2 switch, force the access mode on F0/3 interface switchport mode access and remove the trunk reference.
HTH,
__
Edison.
1) The commutation part of the 6xxx is in CatOS :
sh port 4/7
Port Name Status Vlan Duplex Speed Type
4/7 SWL2 connected trunk full 1000 1000BaseSX
Port Security Violation Shutdown-Time Age-Time Max-Addr Trap IfIndex
4/7 disabled shutdown 0 0 1 disabled 16
Port Num-Addr Secure-Src-Addr Age-Left Last-Src-Addr Shutdown/Time-Left
4/7 0 - - - - -
Port Broadcast-Limit Multicast Unicast Total-Drop Action
4/7 - - - 0 drop-packets
Port Send FlowControl Receive FlowControl RxPause TxPause
admin oper admin oper
4/7 desired off off off 0 0
Port Status Channel Admin Ch
Mode Group Id
4/7 connected auto silent 341 0
Port Status ErrDisable Reason Port ErrDisableTimeout Action on Timeout
4/7 connected - Enable No Change
Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize
4/7 0 0 0 0 0
Port Single-Col Multi-Coll Late-Coll Excess-Col Carri-Sen Runts Giants
4/7 0 0 0 0 0 0 -
Port Last-Time-Cleared
4/7 Fri May 30 2008, 08:34:00
Idle Detection
2)
6xxx :
sh vlan
VLAN Name Status IfIndex Mod/Ports, Vlans
1 default active 5 1/1-2
2/1-2
3/3-21
4/1,4/6
5/8,5/12,5/15
6/5-16
100 VoIP active 107
1002 fddi-default active 6
1003 trcrf-default active 9
1004 fddinet-default active 7
1005 trbrf-default active 8 1003
VLAN Type SAID MTU Parent RingNo BrdgNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
3 enet 100003 1500 - - - - - 0 0
4 enet 100004 1500 - - - - - 0 0
5 enet 100005 1500 - - - - - 0 0
6 enet 100006 1500 - - - - - 0 0
7 enet 100007 1500 - - - - - 0 0
10 enet 100010 1500 - - - - - 0 0
11 enet 100011 1500 - - - - - 0 0
13 enet 100013 1500 - - - - - 0 0
15 enet 100015 1500 - - - - - 0 0
18 enet 100018 1500 - - - - - 0 0
20 enet 100020 1500 - - - - - 0 0
100 enet 100100 1500 - - - - - 0 0
101 enet 100101 1500 - - - - - 0 0
200 enet 100200 1500 - - - - - 0 0
226 enet 100226 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 trcrf 101003 4472 1005 0xccc - - srb 0 0
1004 fdnet 101004 1500 - - - - - 0 0
1005 trbrf 101005 4472 - - 0xf ibm - 0 0
VLAN MISTP-Inst DynCreated RSPAN
1 - static disabled
3 - static disabled
4 - static disabled
5 - static disabled
6 - static disabled
7 - static disabled
10 - static disabled
11 - static disabled
13 - static disabled
15 - static disabled
18 - static disabled
20 - static disabled
100 - static disabled
101 - static disabled
200 - static disabled
226 - static disabled
1002 - static disabled
1003 - static disabled
1004 - static disabled
1005 - static disabled
VLAN AREHops STEHops Backup CRF 1q VLAN
1003 7 7 off
ROUTER :
sh vlan-switch
VLAN Name Status Ports
1 default active Fa0/2/1, Fa0/2/2, Fa0/2/3
100 VoIP_Alcatel active Fa0/2/0
1003 token-ring-default active
1005 trnet-default active
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 1002 1003
1002 fddi 101002 1500 - - - - - 1 1003
1003 tr 101003 1500 1005 0 - - srb 1 1002
1004 fdnet 101004 1500 - - 1 ibm - 0 0
1005 trnet 101005 1500 - - 1 ibm - 0 0
3) DONE but it's still not working
Thank you again
L2 switch :
sh vlan
1 default active Fa0/1, Fa0/4, Fa0/6, Fa0/7,
Fa0/8, Fa0/9, Fa0/10, Fa0/11,
Fa0/12, Fa0/13, Fa0/14, Fa0/15,
Fa0/16, Fa0/17, Fa0/18, Fa0/20,
Fa0/21, Fa0/22, Fa0/23, Fa0/24,
Fa0/26, Fa0/27, Fa0/31, Fa0/32,
Fa0/33, Fa0/34, Fa0/35, Fa0/36,
Fa0/37, Fa0/38, Fa0/39, Fa0/40,
Fa0/41, Fa0/42, Fa0/43, Fa0/44,
Fa0/45, Fa0/46, Gi0/2
100 VoIP active Fa0/2, Fa0/3
1003 trcrf 101003 4472 1005 3276 - - srb 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trbrf 101005 4472 - - 15 ibm - 0 0
1003 7 7 off
Looks good.
You don't have any ACL on any of the interfaces or VACL in either of the switches, right?
Can you connect the router directly to the 6500 switch for testing purposes? Does it work then?
If you were to create a SVI (Switch Virtual Interface) in the L2 switch for Vlan 100, can you ping the 6500 switch and the router?
__
Edison.
