Trunk link not connecting
DHGmem
Frequent Visitor
Frequent Visitor
I'm replacing a switch and I can't get the trunk link to the core connect.
I'm not 100% sure its not the fiber link to the core, but it was previously working and I traced it with a light pen. There are two available fiber links in this comm room and both don't work.
Config is pretty basic on both ends...
interface TenGigabitEthernetX/X/X
switchport
switchport mode trunk
Show interface on both ends...
GigabitEthernetX/X/X is down, line protocol is down (notconnect)
  Full-duplex, 1000Mb/s, media type is 1000BaseLH
I wanted a 10G-LR SFP but I thought it might be compatibility so i changed it back to the original 1G-LX SFP for now.
I've swapped out everything I could think of on both ends...
-Swapped the switch
-Swapped the SFP module
-LC/LC fiber - new out of the package
-Tried multiple SFP's (Same on both ends)
I also plugged the switch directly into the core via 10G-LR SFP LC/LC and it worked.
I don't know what else to try other than get someone to run a new fiber link which could be expensive.
Please help with some ideas to try 🙂
balaji.bandi
Try setting speed 1G or try no autonegotiation interface command.
BB
Seb Rupik
Hi there,
Given your list of hardware checks, have you tried changing the polarity of the fibre at one end?
cheers,
Seb.
paul.driver
Level 3
Level 3
Hello
FYI - 10G will be Single mode, 1GB can be Single or Multimode
So check to see if you have a compatibility issue, also try crossing the TX/RX pins around
mlund
Level 11
Level 11
You wrote " I traced it with a light pen", I have never seen that this is working on single mode fiber. I thought it only works for multimode.
And if your fiber is multimode, and the SFP:s are LX (single mode) that will be a problem. It can maybe work for a very short range with 10G, it reaches a bit longer with 1G, so the advice from @balaji to test with 1G is good. Or try with SX.
/Mikael
