Bookmark
Subscribe
982
Trunk port configuration issue between PVLAN port and other port
AbeysV
I am doing some testing for Private VLAN (PVLAN) configuration. My test setup is as below:
In this setup I have one Access switch and one Distribution switch, I have configured Interface Vlan on Distribution switch which is Default gateway for my PC and Laptop. But I am not able to reach to my Default Gateway. IP of PC is 192.168.1.25 & Laptop IP is 192.168.1.50. Switch configuration of Access switch and Distribution switch are as below:
Distribution switch
interface Vlan300
 ip address 192.168.1.11 255.255.255.0
 no ip route-cache
interface FastEthernet0/11
 description ## Access switch FA0/48 ##
 switchport trunk allowed vlan 300
 switchport mode trunk
 mls qos trust ip-precedence
 udld port aggressive
Access switch
vlan 300
  private-vlan primary
  private-vlan association 301-302
vlan 301
  private-vlan community
vlan 302
  private-vlan isolated
interface FastEthernet0/30
 switchport private-vlan host-association 300 302
 switchport mode private-vlan host
interface FastEthernet0/33
 switchport private-vlan host-association 300 301
interface FastEthernet0/48
 description ## Distriburion switch ##
 switchport private-vlan mapping 300 301-302
 switchport mode private-vlan promiscuous
 switchport nonegotiate
 load-interval 60
 no keepalive
 priority-queue out
 no mdix auto
On Distribution switch when I configure port (FastEthernet 0/11) connecting to Access switch as a Access VLAN then I'm able to reach default gateway but not with trunk configuration. I require switchport configuration as trunk because I have to pass multiple VLANs.
Please help.
6 Replies 6
acampbell
try adding the following line to your Access Switch trunk port.
interface fastethernet 0/48
switchport mode private-vlan trunk
Regards, Alex. Please rate useful posts.
There is no option of switchport mode private-vlan trunk
It's only showing switchport mode private-vlan host or promiscuous
If this is a switch model ME3xxxx you need to make the port NNI 1st to support trunking.
UNI type working is hosts only.
port-type nni
No switch is old, Catalyst 3560.
You are trying to configure PVLAN promiscuous trunk port at the access switch but this feature is not supported with Catalyst 3560 (SE train).
Provided your distribution switch understands PVLANs you can try to modify your setting as follows:
  • Configure Fa 0/48 (access switch) as standard trunk port (the same way as Fa 0/11 of distribution with the "switchport trunk allowed vlan 300-302" modification - both sides).
  • Configure PVLANs at the distribution and under the "Interface Vlan 300" of the distribution configure "private-vlan mapping 301-302".
This way you MAY achieve what you wish.
Good Luck!
Best regards,
Antonin
Hi amikat,
Thanks!
I have configured below way and now I am able to reach from my PC to it's default Gateway which is my L3 box (distribution). Following are the changes I have done on Access switch:
load-interval 60
no keepalive
speed 100
duplex full
priority-queue out
no mdix auto
