Trunk port configured for an Access VLAN.
jokerfmj1
I have been tasked with an environment that is new to me and have been troubleshooting some issues they're having. In reviewing some configurations for them I have noticed that a number of their trunk ports that lead to VM Hosts are configured with an acces vlan statement. For example:
interface Ethernet1/1
  switchport mode trunk
  switchport access vlan 100
  no shutdown
I think that this will essentially ignore the "switchport access vlan 900" command and just act like a trunk, which seems to hold true because I see multiple MAC addresses with different VLAN assignments.
Can anyone confirm or refute this for me?
Thanks.
Reza Sharifi
That is correct. The port mode is "trunk" So
Can be removed as it is not doing anything.
Reza Sharifi
Thanks, Reza. I figured as much I just wanted to double check.
Absolutely agree with you. it is always a good idea to double check before deleting a command.
Good Luck!
