Trunk port not working between C3850 and C3560X
RookieNet55
Hi everyone,
I have C3560X switch which is the current core, trying to add a new switch C3850-24XS via the trunk port. The link status is up, I can see the lights on both ports physically. But no communication between the switches via trunk port, no CDP neighbours either. There is VTP on both switches, C3560X is server and C3850 is configured as client, I have double checked the passwords and they are good.
Any help is appreciated on getting this trunk up and running. I can provide more config info as required.
Below are some configurations.
C3560X side
ip routing
interface Vlan100
description Management VLAN
ip address 172.18.100.1 255.255.255.0
interface GigabitEthernet0/24
switchport trunk native vlan 100
switchport trunk allowed vlan 100
switchport mode trunk
sh int gi0/24 status
Port Name Status Vlan Duplex Speed Type
Gi0/24 new san test connected trunk a-full a-1000 10/100/1000BaseTX
VTP Version                     : running VTP2
Configuration Revision          : 17
Maximum VLANs supported locally : 1005
Number of existing VLANs        : 15
VTP Operating Mode              : Server
VTP Domain Name                 : CDCCORPVTP1
VTP Pruning Mode                : Disabled
VTP V2 Mode                     : Enabled
VTP Traps Generation            : Disabled
MD5 digest                      : 0x89 0x03 0xC4 0x18 0xAD 0x3D 0xAD 0xB3
Configuration last modified by 0.0.0.0 at 3-1-93 00:20:35
Local updater ID is 172.18.2.1 on interface Vl2 (lowest numbered VLAN interface found)
C3850 side
ip routing
interface Vlan100
ip address 172.18.100.9 255.255.255.0
ip route 0.0.0.0 0.0.0.0 172.18.100.1
interface TenGigabitEthernet1/0/24
sh int te1/0/24 status
Te1/0/24 connected trunk a-full a-1000 10/100/1000BaseTX SFP
sh vtp status
VTP Version capable             : 1 to 3
VTP version running             : 2
Device ID                       : 0056.2bd9.1e80
Configuration last modified by 172.18.100.9 at 12-21-23 21:55:55
Feature VLAN:
VTP Operating Mode                : Client
Number of existing VLANs          : 7
Configuration Revision            : 0
MD5 digest                        : 0xB3 0x4C 0x27 0x65 0xCD 0x6D 0x7D 0x1C
                                    0xAF 0x5B 0x02 0x3A 0x60 0x47 0xA0 0xAF
41 Replies 41
even with this config shouldn't the cdp neighbours at least be showing up ?
You disable cdp ?
If not Solve the native  and make stp have one root and check again.
MHM
Unless we disable the cdp on port it is enabled by default right ?
Yes is enable by defualt.
MHM
It is enabled but for some reason, even CDP is not showing any neighbours.
Okay so what you are suggesting is that I simply remove the native vlan on this trunk and just have vlan 100 as allowed ?
Friend there are five trunk four have native vlan 100 and one have 218?
Can you check why is this appear
MHM
This was set up before me, but it seems to be done on purpose as it is connected a vpn appliance and want to have all traffic coming from that port to be tagged with that vlan 218.
OK let me review all info you provide again
thanks
MHM
Thank you for checking this.
Here is another detail I checked. The SFP used on C3850-24XS is "SFP-GE-T". On checking the SFP compatibility with my model, It is compatible.
VLAN0100
  Spanning tree enabled protocol ieee
  Root ID    Priority    32868
             Address     0056.2bd9.1e80
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32868  (priority 32768 sys-id-ext 100)
             Aging Time  300 sec
VLAN0100
             Address     0018.7392.c600
             Aging Time 300
Gi0/24    SAN switch test    connected    trunk      a-full a-1000 10/100/1000BaseTX
from above the interface show connect BUT
the STP see two Root
the CDP not even show neighbor
so there is issue in SFP the packet is not seen from each side
so let check STP is it send receive the BPDU or not check that by below command
cat#show spanning-tree interface gi0/24 detail
Port 130 (GigabitEthernet3/2) of MST00 is backup blocking
   Port path cost 20000, Port priority 128, Port Identifier 128.130.
   Designated root has priority 0, address 0007.4f1c.e847
   Designated bridge has priority 32768, address 00d0.003f.8800
   Designated port id is 128.129, designated path cost 2000019
   Timers: message age 4, forward delay 0, hold 0
   Number of transitions to forwarding state: 0
   Link type is point-to-point by default, Internal
   Loop guard is enabled by default on the port
   BPDU: sent X, received X
for CDP check
SW# show cdp traffic
MHMN
Here is what I tried to test the most basic item. I defaulted the config on both these interfaces on respective switches and then checked the CDP neighbours that doesn't show up anything.
CDP neighbours should still show up when there is physical connectivity between the links right ?
I will be onsite today, so I can test more SFP's and kepp you posted. But sincere thanks again for taking time to look into my problem.
No thanks friend
You are so welcome
MHM
