Trunk port not working between C3850 and C3560X
RookieNet55
Hi everyone,
I have C3560X switch which is the current core, trying to add a new switch C3850-24XS via the trunk port. The link status is up, I can see the lights on both ports physically. But no communication between the switches via trunk port, no CDP neighbours either. There is VTP on both switches, C3560X is server and C3850 is configured as client, I have double checked the passwords and they are good.
Any help is appreciated on getting this trunk up and running. I can provide more config info as required.
Below are some configurations.
C3560X side
ip routing
interface Vlan100
description Management VLAN
ip address 172.18.100.1 255.255.255.0
interface GigabitEthernet0/24
switchport trunk native vlan 100
switchport trunk allowed vlan 100
switchport mode trunk
sh int gi0/24 status
Port Name Status Vlan Duplex Speed Type
Gi0/24 new san test connected trunk a-full a-1000 10/100/1000BaseTX
VTP Version                     : running VTP2
Configuration Revision          : 17
Maximum VLANs supported locally : 1005
Number of existing VLANs        : 15
VTP Operating Mode              : Server
VTP Domain Name                 : CDCCORPVTP1
VTP Pruning Mode                : Disabled
VTP V2 Mode                     : Enabled
VTP Traps Generation            : Disabled
MD5 digest                      : 0x89 0x03 0xC4 0x18 0xAD 0x3D 0xAD 0xB3
Configuration last modified by 0.0.0.0 at 3-1-93 00:20:35
Local updater ID is 172.18.2.1 on interface Vl2 (lowest numbered VLAN interface found)
C3850 side
ip routing
interface Vlan100
ip address 172.18.100.9 255.255.255.0
ip route 0.0.0.0 0.0.0.0 172.18.100.1
interface TenGigabitEthernet1/0/24
sh int te1/0/24 status
Te1/0/24 connected trunk a-full a-1000 10/100/1000BaseTX SFP
sh vtp status
VTP Version capable             : 1 to 3
VTP version running             : 2
Device ID                       : 0056.2bd9.1e80
Configuration last modified by 172.18.100.9 at 12-21-23 21:55:55
Feature VLAN:
VTP Operating Mode                : Client
Number of existing VLANs          : 7
Configuration Revision            : 0
MD5 digest                        : 0xB3 0x4C 0x27 0x65 0xCD 0x6D 0x7D 0x1C
                                    0xAF 0x5B 0x02 0x3A 0x60 0x47 0xA0 0xAF
41 Replies 41
This looks strange and buzzard  for me totally-  never come across these kind of issue before  (until we are hitting any one of the side bugs ?)
My guesses will be :
1. Due to old code in 3650  may be ?
2. Try speed strict to speed 1000 or  no speed negotiation - options
3. I also connect PC directly to port and configure the  IP and test both the side  you able to ping -  the switch to be sure the ports are working (nothing weird going on)
4. you can also making layer 3 interface and test it. (i have suggested other post config)
On 3850 Try debugging see you can find any information : use below STP troubleshooting guide :
https://www.cisco.com/c/en/us/support/docs/lan-switching/spanning-tree-protocol/28943-170.html
BB
Here is what I tried to test the most basic item. I defaulted the config on both these interfaces on respective switches and then checked the CDP neighbours that doesn't show up anything.
CDP neighbours should still show up when there is physical connectivity between the links right ?
I am now suspecting the SFP, the SFP used in my case is "SFP-GE-T" on C3850 side, but no SFP on C3560 because that is just a regular gigabit RJ45 port switch. Also this SFP is officially supported for C3850-24XS but still running into this weird issue.
I will be onsite to test with more SFP's just in case and keep you posted. Sincere thanks for taking time to looking into my issue.
I made an access port on the switch, with vlan 100. The SVI of vlan 100 was 172.18.100.9 255.255.255.0
Ip routing was disabled on this switch.
Tried to connect the laptop and configured the ethernet to be on 172.18.100.55 255.255.255.0 , no gateway and no dns. It is a windows 10 laptop.
And no luck with ping to SVI via the access port. Swapped the SFP's and the cable
So it was indeed the SFP problem. I have was using Startech GLC-T compatible SFP's atleast what is said on the 10pk box, but on the SFP's itself the label was GLC-TST. And on reading the SFP in the switch it was showing up as SFP-GE-T. This SFP-GE-T says it is compatible on cisco compatibility matrix for C3850-24XS
Then I tried an old SFP that was lying around which said GLC-T on physical SFP module, but on reading in the switch it doesn't say the model name. But that worked on C3850's.
A bit confused at the moment.
Leo Laohoo
@RookieNet55 wrote:
  Last input never, output 00:00:01, output hang never
     0 packets input, 0 bytes, 0 no buffer
If the ports are not trunk, does it work?
You mean to say I switch to access ports on both ends and test ?
Yes.
And use Gi ports and not Ten port.
I tried setting both as access ports
switchport mode access
switchport access vlan 100
Above is the config on both ports of the both the switches. Ping doesn't work to either switches SVI vlan 100 ip's.
Regarding the Tengigabit port, I don't see the gigabit version of the same port when I run "sh ip int br", though the sfp is used is a 1gig copper
Can we see the "sh interface" of the output from the 3850?
sh interface te1/0/24
TenGigabitEthernet1/0/24 is up, line protocol is up (connected)
  Hardware is Ten Gigabit Ethernet, address is 0056.2bd9.1e98 (bia 0056.2bd9.1e98)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000BaseTX SFP
  input flow-control is on, output flow-control is unsupported
  Last input never, output 00:00:00, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 1000 bits/sec, 1 packets/sec
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     47196 packets output, 3724370 bytes, 0 underruns
     Output 3893 broadcasts (0 multicasts)
     0 output errors, 0 collisions, 5 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Show interface trunk
Show stp in both SW for vlan 100
Show interface status
MHM
Important thing is no cdp neighbours
sh interface trunk on C3850
sh int trunk
Port        Mode             Encapsulation  Status        Native vlan
Te1/0/24    on               802.1q         trunking      100
Port        Vlans allowed on trunk
Te1/0/24    1-4094
Port        Vlans allowed and active in management domain
Te1/0/24    1,100
Port        Vlans in spanning tree forwarding state and not pruned
Te1/0/24    1,100
STP vlan 100 on C3560 and interface status
VLAN0100
  Spanning tree enabled protocol ieee
  Root ID    Priority    32868
             Address     0018.7392.c600
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32868  (priority 32768 sys-id-ext 100)
             Aging Time 300
Interface           Role Sts Cost      Prio.Nbr Type
Gi0/2               Desg FWD 4         128.2    P2p
Gi0/3               Desg FWD 4         128.3    P2p
Gi0/23              Desg FWD 4         128.23   P2p
Gi0/24              Desg FWD 4         128.24   P2p
Gi0/24    SAN switch test    connected    trunk      a-full a-1000 10/100/1000BaseTX
STP vlan 100 on C3850 and interface status
VLAN0100
             Address     0056.2bd9.1e80
             Aging Time  300 sec
Te1/0/24            Desg FWD 4         128.24   P2p
two root bridge!!!
can I see
show interface trunk in both SW
MHM
Here is the trunk interfaces from the core switch C3560X
sh int trunk
Gi0/2       on               802.1q         trunking      100
Gi0/3       on               802.1q         trunking      100
Gi0/18      on               802.1q         trunking      218
Gi0/23      on               802.1q         trunking      100
Gi0/24      on               802.1q         trunking      100
Gi0/2       2-3,52,100,218,301-304
Gi0/3       52-53,100
Gi0/18      218
Gi0/23      100
Gi0/24      1-4094
Gi0/3       52,100
Gi0/18      218
Gi0/23      100
Gi0/24      1-3,52,100,218,301-304,1000
Gi0/3       52,100
Gi0/18      218
Gi0/23      100
as I guess there is two native in one SW this make STP not elect the correct root and all issue you face from this misconfig
match native vlan in all your SW and check.
MHM
