04-24-2017 07:57 AM - edited 03-08-2019 10:18 AM
Hi were trying to setup trunk ports with a number of vlans from a pair of Nexus 5548(with sw 6.0.(2)N2(5)) with a dual homed FEX Nexus 2232TM-E connected to a to a ESXi-host with 10GBase-T to a configured dvSwitch to handle the trunk vlans
With a trunk with ordinary vlans it works just fine, port config below:
interface Ethernet102/1/9
description esxi-host-01
switchport mode trunk
switchport trunk native vlan 999
switchport trunk allowed vlan 1-2,5,11,15,20,25,30,35,38,40,42,44-46,64,98-99,105,110,115,120,125,130,135,140,145,155,170,180,188,190,194-202,210-212,220-222,230-232,240-243,246-247,301-306,312,320,400,402,410,412,500,910-912,940,980-983,986-988,992,996,998-999,1006,1012,1014-1015,1020,1032-1037,1041-1042,1048-1055,1100
spanning-tree port type edge trunk
But when we try to use the private vlans on a dvSwitch in another esxi-host, with the same config as above, the virtual machines cannot communicate at all
It seems like the esxi's pvlans are not transported through the trunk to the Nexus
One example of many private vlans config in Nexus, configured on the trunk port:
vlan 301
name 301-Primary
private-vlan primary
private-vlan association 302
vlan 302
name 302-Community
private-vlan community
The esxi-host were previously connected to a Catalyst 4948 (etherchannel trunk) and were able to use the configured pvlans without any problems
Whats wrong here?
Please advise
Note/Comment: I've seen this command in some articles (we dont have it enabled): system private-vlan fex trunk
It seems that this might help me to make this work, any comments on what this can do to the running system when enabled??
Solution edit: The command system private-vlan fex trunk did the trick without any problems and the ESXi-hosts got the private vlans correctly
Hope this can help someone
05-12-2017 07:12 AM
Thanks for the feedback!
