05-10-2017 02:24 AM - edited 03-08-2019 10:31 AM
Hello All,
I have encountered a really odd problem (at least it is odd for me :) ) and I would like to ask your help to get understand it.
So, there are two routers (primary and secondary) connected to a switch.If the primary WAN link goes down then the fail-over does not work. Actually, it partly works.
Some apps do work but the rest does not. When a local user starts a traceroute towards to another location on his computer, traffic always goes towards the primary router. So, the 2nd hop is always the primary router even though it's WAN link is down.
In case of the servie is having the above mentioned issue, we see the following routes on the switch coming from the R1 router:
SW1#sh ip route | in 10.10.10.102
O E1 10.0.0.0/8 [110/101] via 10.10.10.102, 1d11h, Vlan10
This is the only one route that being advertised by the primary router. Switch received routes for secondary router as well.
On R1 if we check the routing table we can see this (when fail-over is taking place):
R1(config-router)#do sh ip route | inc 10.0.0.0
10.0.0.0/8 is variably subnetted, 20 subnets, 10 masks
O 10.0.0.0/8 is a summary, 00:05:11, Null0
So, the SW1 can receive the route because R1 sending it. Ok. If I am not mistaken, OSPF marks this route with a NULL0 in order to avoid loop if it does not know how to forward the packets. (unknown next-hop). So that, because of this, the traffic is going to the "black-hole" in case of fail-over. IF WAN link is up , we receive 10.0.0.0/8 from WAN cloud.
OSPF config:
router ospf 10
summary-address x
summary-address y
summary-address z
summary-address xx
summary-address yy
summary-address zz
summary-address xxx
summary-address yyy
summary-address zzz
summary-address 10.0.0.0 255.0.0.0
redistribute bgp 1 metric 100 metric-type 1 subnets
network 10.10.10.80 0.0.0.15 area 0
default-information originate metric 10
default-metric 100
On the R2 OSPF config is similar but the metric is higher. (10->20, 100->200)
What I do not understand is that , why is OSPF always advertising only that particular network? We have a lot of summary routes defined in OSPF and the mentioned one is the only one that being advertised if fail-over happens.
Any idea, what does cause this behaviour?
Thanks a million for your help!
Cheers,
Gabor
05-10-2017 02:43 AM
if you are getting the 10.0.0.0/8 from WAN cloud do not summarize it.
05-10-2017 04:43 AM
Routers learn other subnets from WAN and they are summarised in OSPF as well but they don't cause any issues. Why ? I still do not understand it.
05-10-2017 05:55 AM
because of this you have
in you routing table on both routers R1 and R2
they both advertise this route to the SW1 but R1 is better
so in the situation when R1 lost wan connection you have a black hole.
05-10-2017 06:53 AM
Yes, I know it. But, Why does it work this way ? Why only one route ?
I know how to solve the problem, I am interesting in the route-cause that triggers this behaviour.
05-10-2017 10:42 PM
Hi there,
Blame RFC and its default behavior and is expected. To avoid this you may use below command under OSPF
router ospf x
no discard-route internal
end
Hitesh
05-12-2017 05:37 AM
Thanks for pointing this out. It makes sense....
05-10-2017 03:26 AM
Pick up the destination IP which isn't accessible and paste output of "sh ip route x.x.x.x" from R1, R2 and SW.
Hitesh
05-10-2017 04:39 AM
I can not see any suspicious thing. R1 and R2 knows the route via WAN BGP.
There is no assymetric routing between R1 and R2 or something like that.
Unfortunately, I can not send output from Sw1 as it does not managed by me.
R1#sh ip route 10.33.72.76
Routing entry for 10.33.72.0/21
Known via "bgp 1", distance 20, metric 0
Tag 2, type external
Redistributing via ospf 10
Last update from 10.73.110.65 1w4d ago
Routing Descriptor Blocks:
* 10.73.110.65, from 10.73.110.65, 1w4d ago
Route metric is 0, traffic share count is 1
AS Hops 2
Route tag 2
MPLS label: none
R2(config-router)#do sh ip route 10.33.72.76
Last update from 10.73.133.83 00:00:39 ago
* 10.73.133.83, from 10.73.133.83, 00:00:39 ago
AS Hops 2
Route tag 2
MPLS label: none
