Trunk problem
Tshi M
Level 9
Level 9
what will cause a switch to see itself in the CDP while trying to establish a trunk?
szahid
Level 8
Level 8
somehow the port is looped . One reason you will see that is when a port goes to a hub and hub has 2 connections back to the switch.
it is a fiber to fiber connectivity. The 4503 which sees itself in the CDP is connected to a 3560 through a fiber cable.
it looks like a bad module:
Nov 12 18:49:15.166 est: %C4K_GBICMAN-3-GBICSEEPROMREADFAILED: Failed to read gbic serial eeprom on port Gi1/1, try reinserting
