Trunk to Hyper-V hosts won't come up
Colin Higgins
Level 2
Level 2
I have two 6513s running VSS with Supervisor 2T modules (quad sup VSS SSO)
I want to create a 802.1q trunk (multi-chassis) between the switches and a Microsoft Hyper-V 2012 machine (host).  On the Hyper-V machine, I establish a 4 network adapter team using "switch independent" (not static or LACP config) encapsulation, and within virtual switch manager, assign the new team as a switch. The server creates a special logical (virtual) nic and I give it an Ip address.
On the switch, the trunk is configured like this
interface po34
switchport
switchport mode trunk
switchport trunk native vlan 313
switchport trunk allowed vlan 313,320-322
interface g1/1/1
switchport
channel-group 34 mode desirable
The individual network cards on the server come up, but the port-channel and trunk never come up.
It seems like I have tried everything to get this to work.
Has anyone done this? Can you do a dot1q trunk to a Hyper-V host? (MS says you can). I don't even see anything in the switch logs.
P.S. I can doa LACP etherchannel connection no problem.
Colin,
PAGP is used normally JUST between 2 Cisco devices like SWITCH to SWITCH
LACP (mode active or passive - at least one end must be active) This will use 802.1Q trunking if you have configured the "interface port"  it to do that.
LACP can used for either LAYER2 or LAYER 3
This link may help:-
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/channel.html
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
acampbell
Colin,
"channel-group 34 mode desirable"
This set the port channel to use PAGP - this is Cisco proprierty
Try setting "channel-group 34 mode active" and that will try LACP
You final option is
"channel-group 34 mode on"  that is no negotiation -just forced ON
Alex.
If I use LACP, will it function as a 802.1q trunk and carry vlan info to the hyper-v host? I thought that was only for link aggregation with a single layer 3 interface?
If I use the "mode on" option, the links go into a suspended state and the port-channel interface stays down.
Colin,
Alex.
OK, I figured it out
On the Hyper-V side, it HAS to be hard-coded to LACP (switch independent or dependent will not work)
On the switch side, you need to use "switchport nonegotiate" and hard-code to LACP as well.
