01-29-2021 06:43 AM
I'm trying to create a trunk on a Cicso C2960X switch on port 1/0/48. in the 'sh int status' it says that port 1/0/48 is a trunk. but when i type 'sh int gi1/0/48 trunk it shows that there are not vlan allowed on the trunk:
To add a vlan to the trunk I type:
-conf
-int gi1//0/48
-switchport mode trunk
-switchport trunk allowed vlan 1, 117, 126
-end
-wr
configuration switches and netwerking is all fairly new to me, and i dont know why its not working.
01-29-2021 06:46 AM
Do you have VLAN created 117 and 126
can you post show vlan
01-29-2021 07:09 AM
Yes the vlans are created and the vlans are also working.
We have more Cisco switches at the factory, but they where configured by some one who left the company, and atm there is no one internally I can ask for help. 1 of them also has a working trunk on a gi-port.
01-29-2021 07:29 AM
Check -
1) the port is up
2) the port on the other end of the link is up and is configured as trunk as well
Jon
01-29-2021 07:54 AM
Post below information :
show interface gi1//0/48
show interface gi1//0/48 capabilities.
Or do below steps and let us know. ( make sure you remove the cable and below steps and conenct back)
conf t
default int gi1//0/48
int gi1//0/48
no shut
02-01-2021 02:21 AM
her are screenshot of the info you asked.
when i trie to type the code you provided i got an error on the word 'encapsulation'
Kr,
Sander
02-01-2021 02:31 AM
The port already dot1.q, so the command not required (switchport trunk encapsulation dot1q)
can you post
show version
show run
show spann summary
01-29-2021 08:02 AM
It is strange that the status is other on the trunk.
Could you try and do a show int status err-disabled and show int status?
01-30-2021 01:37 PM
Hello.
Thank you for the reply's. On Monday I'll try the different solutions and'll supply screenshot, at home I can't connect to the switch. Also, the trunk I create connects to an old 3Com switch, on a port that is also a trunk (alto on the 3Com I needed to assign tagged and untagged vlans).
01-30-2021 04:23 PM
keep us post what is the outcome, more interested to see what was the fix for you. still has an issue, do not forget to give your input information to understand better of the issue here.
02-01-2021 02:51 AM
And try to do a switchport nonegatiate just to make sure DTP is disabled on the Cisco switch if it is connected to a 3-party switch.
01-30-2021 06:44 AM
trunk status is show OTHER not trunk
this trunk is connect to second SW ? are second SW have same encapsulation ? are both use DTP for trunk?
I think the problem not in this SW it is in second SW.
02-01-2021 02:33 AM
The switch in question is connected with fiber to our backbone switch. so it's backbone -> switch Cisco -> 3com that is the set-up i need.
but, it shouldn't matter right, how the 2nd switch is configed, the allowed vlan should show on the switch.
Kr,
Sander
01-30-2021 07:42 AM - edited 01-30-2021 07:46 AM
Hello
FYI it doesn't matter if the other end of the trunk isn't configured. As long as the switchport interface that is to be a trunk is enabled as a trunk and also is active it should show the correct vlans allowed to cross the trunk, those that are allowed and active on the switch, But it wont show vlans in a stp forwarding state if they are are being pruned.
In your case its possibly a bug in software of switch, Can you post the feature-set version and sdm template of the switch
sh version
sh sdm prefer
02-01-2021 02:27 AM
Hello Paul,
her are 2 screenshot of the sh version & sh sdm prefer.
Kr,
Sander
