trunked port active in vlan
michellp
Maybe there's an obvious answer, but I have this strange thing;
Switchport config
interface GigabitEthernet0/2
 description Trunk to CORE02
 switchport mode trunk
 shutdown
 srr-queue bandwidth share 10 10 60 20
 queue-set 2
 priority-queue out
 mls qos trust cos
 auto qos voip trust
sh vlan brie
VLAN Name                             Status    Ports
1    default                          active    Gi0/2
Why is it that this port, which is configured as a trunk port, shows up as active in vlan1? Also when I do a show interfaces trunk, this specific port is not listed as a trunked port. By the way I had to shutdown the port because it was causing issues. It's a redundant link, when enabled I would expect spanning tree to do it's magic, but somehow it does not and instead causes half of our lan to become unreachable. Not sure why.
7 Replies 7
Tagir Temirgaliyev
it is hidden config
you can see hidden config
sh runn all
sh runn all | beg interface GigabitEthernet0/2
 switchport
 switchport access vlan 1
and dont forget to rate posts
Hmz,
sh running-config all | b GigabitEthernet0/2
 shutdown
 queue-set 2
 priority-queue out
 mls qos trust cos
 snmp trap link-status
 auto qos voip trust
No difference. Could it be that 'show vlan brief' command shows the active/current status and because the port is shutdown and thus not actually active as a trunk it still shows up as it's default setting which is access port in native vlan (vlan 1)?
I have to reply to my own question, as what I suspected is true. I just took two test switches and tried it out.
So,
It seems this is indeed the case
it is ios bug.
what is your ios ?
when both configured
interface GigabitEthernet1/0/41
it is trunk port
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(44)SE6, RELEASE SOFTWARE (fc1)
I've seen this and assumed this is because trunk mode overrules access mode. I also have a setup where one switchport is configured as access port and the port on the other switch as trunk, but show commands reveal that the port is in trunk mode on both switches. I believe this is no bug.
in my switch I can not delete it
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C2960S-48TS-L   12.2(58)SE2           C2960S-UNIVERSALK9-M
 description 2960_24_POE_5_24
 spanning-tree portfast
_Cat_2960s_5_1#sh vla br
1    default                          active    Gi1/0/41,
_Cat_2960s_5_1#
_Cat_2960s_5_1#sh runn all | b interface GigabitEthernet1/0/41
 switchport
 switchport private-vlan trunk encapsulation dot1q
 switchport private-vlan trunk native vlan tag
 no switchport nonegotiate
 no switchport protected
 no switchport block multicast
 no switchport block unicast
 switchport port-security maximum 1
 no switchport port-security
_Cat_2960s_5_1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
_Cat_2960s_5_1(config)#interface GigabitEthernet1/0/41
_Cat_2960s_5_1(config-if)#no switchport access vlan 1
_Cat_2960s_5_1(config-if)#^Z
_Cat_2960s_5_1#
_Cat_2960s_5_1#
_Cat_2960s_5_1#
_Cat_2960s_5_1#
_Cat_2960s_5_1#
_Cat_2960s_5_1#
 switchport
another trunk port with native vlan configured is not in vlan 1
Can you execute this command :
show int status
if the Gigabit0/2 is notconnected then you can see, when you execute show vlan, the interface GigabitEthernet0/2 as status active. if the Gigabit0/2 is connected then the interface Gigabit0/2 is not in the output of the command
