CDP neighbor
Jim Kerr
Hi All
After recently checking cdp neighbors on our LAN switch (3750-e) I noticed amongst the recognised neighbors (connected switches and IP Phones) that there is an entry for a client device (laptop) connected to a particular interface which shows:
MSI on Wi Local Area Connection
Any ideas ? I'm presuming it maybe something to do with voice ?
rkarun
Hi Mick,
The reason you are seeing the PC in your output for "show cdp neighbor" is because the laptop has Media Services interface installed and you are running some Cisco UC application such as jabber or webex or some 3 rd party endpoint. It is usually used for voice/data/video.
Rupesh
OK thanks Rupesh - I guess this would be a normal occurence then? - we normally just see the IP Phones as neighbors - this is the 1st I've seen with an actual client laptop.
thanks
Mick
This is a normal occurrence. At a high level here are the key areas that Medianet addresses:
  • Auto-configuration: managing moves, adds, and changes limiting human configuration errors for QoS.
  • Media Monitoring: Enhances visibility into the network. It helps accelerate troubleshooting, and assess and measure the impact of video, voice, and data applications in the network.
  • Media Awareness: The network works together with applications for optimal QoE for end-users.
If you require more information about MSI and Medianet you can go ahead and refer the link below:
http://www.cisco.com/web/solutions/trends/medianet/indepth.html
Rupesh
thats great - Thanks Rupesh.
Mick
