Trunking Cisco ESW-520 8 port and Cisco Catalyst 3560G
ashley_dew
I have a Cisco ESW520 8 port that is connected to a cisco catalyst 3560G.
Our switch management is on VLAN 100 and vlan 1 is the data network.
I have trunked the two switchs and on the interface of the 3560G is as follows:
interface GigabitEthernet0/6
switchport trunk native vlan 100
switchport trunk allowed vlan 1,100
switchport mode trunk
ip dhcp snooping trust
On the switch ESW, i have used the smartport macro Switch with native vlan 100 and allowed vlan 1,100 on the gigabit uplink and desktop macro vlan 1 on the other ports.
Now, the native vlan works fine, I can access the ESW switch from the vlan 100 from the 3560G vlan 100.
The problem is that the vlan 1 is not being trunked and I cannot access the vlan 1 at all, from the ESW 520.
I cannot see the issue here.
Thanks for your help,
Ashley
datamex
Hey Ashley,
It seems i have a simular problem but than with a cisco router 878 to a ESW 520-8p. I can access the native vlan 1 on the esw switch but the ip address i configured for the vlan 2 ( our voice vlan ) i can't access.
An other location i have 2 cisco catalyst switches 2960 and these are working fine with the router configuration. I can access from the other location the second vlan on the cisco router 878. with the ESW 520-8p connected.
I am wondering if you solved the issue in the time you posted this messages?
best regards,
Fred
letsgomets
I am willing to bet the 520 is not forwarding traffic on VLAN1. There is nothing wrong with the 3560 config.
However I personally would never use VLAN 1 for anything because that is the default VLAN for any undefined ports. Additionally I would never use a Native VLAN that has valid host traffic on it. In your case your management network. That is a L2 security risk. The Native VLAN should be exclusive to only trunking information.
I am not familiar at all with the "smartport macro" but on the 520 you need to ensure that the uplink is indeed configured as a trunk and it permitted to forward (tag) VLAN 1 traffic.
Perhaps this link will help. It sounds similar to your problem.
https://supportforums.cisco.com/thread/2044370
