Trunking Cisco Nexus 3048 with a Force10 S4810
03fastmach1
Hi there,
While I am an experienced systems guy, I am relatively new to network infrstructure. I have been assigned the task of trunking VLAN between a Nexus 3048 and a Force10 S4810. This would seem easy enough but I am really having a bear of a time getting it to work. Any help is greatly appreciated. I have devices configured on VLAN 602 on both sides but they just are not talking.
NX0S 3048
interface configuration
interface Ethernet1/49
  switchport mode trunk
VLAN configuration
VLAN Name                             Status    Ports
1    default                          active    Eth1/13, Eth1/14, Eth1/15
                                                Eth1/16, Eth1/17, Eth1/18
                                                Eth1/19, Eth1/20, Eth1/21
                                                Eth1/22, Eth1/23, Eth1/24
                                                Eth1/49, Eth1/50, Eth1/51
                                                Eth1/52
600  OOB                              active    Eth1/49, Eth1/50, Eth1/51
                                                Eth1/52
602  Production                       active    Eth1/25, Eth1/26, Eth1/27
                                                Eth1/28, Eth1/29, Eth1/30
                                                Eth1/31, Eth1/32, Eth1/33
                                                Eth1/34, Eth1/35, Eth1/36
                                                Eth1/37, Eth1/38, Eth1/39
                                                Eth1/40, Eth1/41, Eth1/42
                                                Eth1/43, Eth1/44, Eth1/45
                                                Eth1/46, Eth1/47, Eth1/48
                                                Eth1/52
604  Storage                          active    Eth1/49, Eth1/50, Eth1/51
                                                Eth1/52
606  ClientVPN                        active    Eth1/49, Eth1/50, Eth1/51
                                                Eth1/52
608  Test                             active    Eth1/49, Eth1/50, Eth1/51
                                                Eth1/52
610  Backup                           active    Eth1/49, Eth1/50, Eth1/51
                                                Eth1/52
700  Headquarters                     act/lshut Eth1/11, Eth1/49, Eth1/50
                                                Eth1/51, Eth1/52
800  HOUHQ-HOUDC                      active    Eth1/12, Eth1/49, Eth1/50
                                                Eth1/51, Eth1/52
1000 DMZ                              active    Eth1/1, Eth1/2, Eth1/3, Eth1/4
                                                Eth1/5, Eth1/6, Eth1/7, Eth1/8
                                                Eth1/9, Eth1/10, Eth1/49
                                                Eth1/50, Eth1/51, Eth1/52
Remote SPAN VLANs
Primary  Secondary  Type             Ports
Force10 S4810
interface TenGigabitEthernet 0/0
no ip address
switchport
no shutdown
VLAN configuration
Codes: * - Default VLAN, G - GVRP VLANs, R - Remote Port Mirroring VLANs, P - Primary, C - Community, I - Isolated
Q: U - Untagged, T - Tagged
   x - Dot1x untagged, X - Dot1x tagged
   G - GVRP tagged, M - Vlan-stack, H - VSN tagged
   i - Internal untagged, I - Internal tagged, v - VLT untagged, V - VLT tagged
    NUM    Status    Description                     Q Ports
*   1      Active                                    U Te 0/1-2
    600    Inactive                                  T Te 0/0
    602    Active                                    T Te 0/0
                                                     U Te 0/12
    604    Active                                    T Te 0/0
                                                     U Te 0/36-47
    606    Inactive                                  T Te 0/0
    608    Inactive                                  T Te 0/0
    610    Inactive                                  T Te 0/0
    700    Inactive                                  T Te 0/0
    800    Inactive                                  T Te 0/0
    1000   Inactive                                  T Te 0/0
03fastmach1
ok... turns out I had the cable plugged into the wrong port on the S4810. FYI... Cisco Nexus is numbered top to bottom. Force10 S4810 is numbered bottom to top.
