Trunking question from NOOB GUY
WIZARD1325
my trunking doesnt show at all when i do
show int trunk
but when i do show in fa1/0/5 switchport
SW1#show int fa1/0/5 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: down
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 10 (SUPPPORT)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
any idea what im doing wrong ? also why is operational mode (down) in the book it says it shows up
running 3570 switch with 12.4v
thanks
johnd2310
Level 8
Level 8
Is that interface connected? The interface needs to be connected to something for it to come up as trunk.
John
**Please rate posts you find helpful**
you know what i am not gonna lie, I was thinking the same stupid freaking thing.
I was just 2 lazy to hook up my second switch in my server rack im such a idiot.
hhahahah.  im going to try it let you know if that did the trick
Thanks!
WIZARD1325
ok so that did the trick
but it raised another question
When i put the first switch to (desirable) and the second to (desirable) there was a conflict in the VTP.
My book says that D to D a trunk will be formed.
but when I put one an auto seem to work.
my question is why didnt it work when i put the second switch on Desirable
and i recieved an DTP mismatch error?
Can you post the port configuration of both switches.
John
