Trunking
52j22304
Community Member
An interface whose trunk encapsulation is "Auto" can not be configured to "trunk" mode.
I got this message while I'm configring etherchannel, in specific it was in " interface port-channel 2"
M02@rt37
Hello @52j22304
Please try enter the command "switch(config-if)#switchport trunk encapsulation dot1q" first.
Then try to configurre the interface as a trunk again.
Best regards
balaji.bandi
Agreed with M02@rt37 - the command need to apply on the Physical interface or interface port-channel.
BB
Port channel need all port member hardcoded it trunk encap and trunk/access mode
I.e. you can use DTP and auto encap for port member
Why?
image one port is access and other is trunk because we use DTP
Or
One port encap ISL abd other dot1q
So it mandatory to hardcoded these settings before port is bundle to PO
MHM
