Packet Tracer is not longer working on unbuntu 18.04
Arik
Hello from Germany,
packettracer worked verry fine for me on Ubuntu 18.04 - I worked with the 7.2.2 Version.
But now after the hollydays packettracer dont't start anymore.
I found that the download on your page has changed for the 7.2.2 from *.tar.gz file to a *.setup.run file.
This File isn't working on my machine.
The other versions can be installed, but when I log in the Programm crashes after entering the username and pressing enter.
When im starting it via the shell entering packettracer, this is what I get:
arik@helpdesk:~$ packettracer
Starting Packet Tracer 7.1.1
/usr/local/bin/packettracer: Zeile 8: 3886 Gleitkomma-Ausnahme (Speicherabzug geschrieben) ./PacketTracer7 "$@" > /dev/null 2>&1
arik@helpdesk:~$ sudo su
[sudo] Passwort für arik:
root@helpdesk:/home/arik# packettracer
/usr/local/bin/packettracer: Zeile 8: 5089 Gleitkomma-Ausnahme (Speicherabzug geschrieben) ./PacketTracer7 "$@" > /dev/null 2>&1
/usr/local/bin/packettracer: Zeile 8: 4036 Gleitkomma-Ausnahme (Speicherabzug geschrieben) ./PacketTracer7 "$@" > /dev/null 2>&1
arik@helpdesk:~$
Can you please help me, I need it in school!?
Greetings from Germany,
Arik
13 Replies 13
do you have access to, and can you try and install, the latest version, 7.3.0 ?
I downloaded packettracer via the netacademy. so there is no 7.3.0...?
Greetings
Arik
the below screenshot is what I see in the download section:
Hi, there thanks for your picture,
I searched again, and guess what, now i found it, because my download
section looks an other way than yesterday...
see the picture...
And I found out something with my issue: The program crashes with a
normal login, but when I use the guest login in the right down corner,
it works.
Greetings,
Arik
So this happens even after installing version 7.3.0 ?
I just installed version 7.3 and Think I’m going to work with it tomorow, when I’m back on the packettracer course….
Of course I will report!
Curious to know if it works...
Hello again,
this morning I came back to packet tracer 7.3 on ubuntu...
And all I can say is that this is the first packet tracer version I tried, which is working perfect!
Thanks for your help!
I have done chapter 5 & 6 Introduction to the packet tracer and it works!
Happy greetings from germany!
Arik
glad that you got it to work ! Good luck with your studies !
Hi every one, I have a problem with the instalation in fedora, when I try to launch whit my email an press "Next", the app close an appear this say's in the consloe:
/usr/local/bin/packettracer: line 8: 7715 ./PacketTracer7 "$@" > /dev/null 2>&1
I put the information about the dependences, and I dont think hava any problem:
ldd /opt/pt/bin/PacketTracer7
linux-vdso.so.1 (0x00007ffe4bbf6000)
libcrypto.so.1.0.0 => /lib64/libcrypto.so.1.0.0 (0x00007fd07d8c2000)
libQt5WebKitWidgets.so.5 => /lib64/libQt5WebKitWidgets.so.5 (0x00007fd07d86f000)
libQt5WebKit.so.5 => /lib64/libQt5WebKit.so.5 (0x00007fd07a9d5000)
libQt5Multimedia.so.5 => /lib64/libQt5Multimedia.so.5 (0x00007fd07a8d7000)
libQt5PrintSupport.so.5 => /lib64/libQt5PrintSupport.so.5 (0x00007fd07a85f000)
libQt5Svg.so.5 => /lib64/libQt5Svg.so.5 (0x00007fd07a803000)
libQt5Widgets.so.5 => /lib64/libQt5Widgets.so.5 (0x00007fd07a157000)
libQt5Gui.so.5 => /lib64/libQt5Gui.so.5 (0x00007fd079c18000)
libQt5Network.so.5 => /lib64/libQt5Network.so.5 (0x00007fd079a56000)
libQt5Xml.so.5 => /lib64/libQt5Xml.so.5 (0x00007fd079a13000)
libQt5Script.so.5 => /lib64/libQt5Script.so.5 (0x00007fd079766000)
libQt5ScriptTools.so.5 => /lib64/libQt5ScriptTools.so.5 (0x00007fd079688000)
libQt5Sql.so.5 => /lib64/libQt5Sql.so.5 (0x00007fd079637000)
libQt5Core.so.5 => /lib64/libQt5Core.so.5 (0x00007fd079103000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007fd0790e1000)
libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007fd078ee7000)
libm.so.6 => /lib64/libm.so.6 (0x00007fd078da1000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007fd078d87000)
libc.so.6 => /lib64/libc.so.6 (0x00007fd078bbc000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007fd078bb5000)
libz.so.1 => /lib64/libz.so.1 (0x00007fd078b9b000)
libQt5Quick.so.5 => /lib64/libQt5Quick.so.5 (0x00007fd0786bd000)
libQt5WebChannel.so.5 => /lib64/libQt5WebChannel.so.5 (0x00007fd078699000)
libicuuc.so.63 => /lib64/libicuuc.so.63 (0x00007fd0784c6000)
libQt5Positioning.so.5 => /lib64/libQt5Positioning.so.5 (0x00007fd078437000)
libX11.so.6 => /lib64/libX11.so.6 (0x00007fd0782f1000)
libicui18n.so.63 => /lib64/libicui18n.so.63 (0x00007fd07800e000)
libQt5Sensors.so.5 => /lib64/libQt5Sensors.so.5 (0x00007fd077fcb000)
libwoff2dec.so.1.0.2 => /lib64/libwoff2dec.so.1.0.2 (0x00007fd077fbc000)
libjpeg.so.62 => /lib64/libjpeg.so.62 (0x00007fd077f37000)
libpng16.so.16 => /lib64/libpng16.so.16 (0x00007fd077eff000)
libwebp.so.7 => /lib64/libwebp.so.7 (0x00007fd077e8e000)
libhyphen.so.0 => /lib64/libhyphen.so.0 (0x00007fd077e86000)
libxml2.so.2 => /lib64/libxml2.so.2 (0x00007fd077d1d000)
libxslt.so.1 => /lib64/libxslt.so.1 (0x00007fd077cd9000)
libsqlite3.so.0 => /lib64/libsqlite3.so.0 (0x00007fd077bbf000)
libgio-2.0.so.0 => /lib64/libgio-2.0.so.0 (0x00007fd0779e1000)
libgstapp-1.0.so.0 => /lib64/libgstapp-1.0.so.0 (0x00007fd0779cf000)
libgstbase-1.0.so.0 => /lib64/libgstbase-1.0.so.0 (0x00007fd077950000)
libgstreamer-1.0.so.0 => /lib64/libgstreamer-1.0.so.0 (0x00007fd077809000)
libgstpbutils-1.0.so.0 => /lib64/libgstpbutils-1.0.so.0 (0x00007fd0777ca000)
libgstaudio-1.0.so.0 => /lib64/libgstaudio-1.0.so.0 (0x00007fd07774d000)
libgsttag-1.0.so.0 => /lib64/libgsttag-1.0.so.0 (0x00007fd07770d000)
libgstvideo-1.0.so.0 => /lib64/libgstvideo-1.0.so.0 (0x00007fd07765c000)
libgstfft-1.0.so.0 => /lib64/libgstfft-1.0.so.0 (0x00007fd07764f000)
libgobject-2.0.so.0 => /lib64/libgobject-2.0.so.0 (0x00007fd0775f3000)
libglib-2.0.so.0 => /lib64/libglib-2.0.so.0 (0x00007fd0774cb000)
libQt5Qml.so.5 => /lib64/libQt5Qml.so.5 (0x00007fd076fe8000)
librt.so.1 => /lib64/librt.so.1 (0x00007fd076fdb000)
/lib64/ld-linux-x86-64.so.2 (0x00007fd07dc8b000)
libpulse.so.0 => /lib64/libpulse.so.0 (0x00007fd076f85000)
libGL.so.1 => /lib64/libGL.so.1 (0x00007fd076ef1000)
libharfbuzz.so.0 => /lib64/libharfbuzz.so.0 (0x00007fd076df9000)
libssl.so.1.1 => /lib64/libssl.so.1.1 (0x00007fd076d63000)
libcrypto.so.1.1 => /lib64/libcrypto.so.1.1 (0x00007fd076a81000)
libsystemd.so.0 => /lib64/libsystemd.so.0 (0x00007fd0769ce000)
libpcre2-16.so.0 => /lib64/libpcre2-16.so.0 (0x00007fd07694a000)
libicudata.so.63 => /lib64/libicudata.so.63 (0x00007fd074f59000)
libxcb.so.1 => /lib64/libxcb.so.1 (0x00007fd074f2e000)
libwoff2common.so.1.0.2 => /lib64/libwoff2common.so.1.0.2 (0x00007fd074f27000)
libbrotlidec.so.1 => /lib64/libbrotlidec.so.1 (0x00007fd074f18000)
liblzma.so.5 => /lib64/liblzma.so.5 (0x00007fd074eef000)
libgmodule-2.0.so.0 => /lib64/libgmodule-2.0.so.0 (0x00007fd074ee9000)
libmount.so.1 => /lib64/libmount.so.1 (0x00007fd074e86000)
libselinux.so.1 => /lib64/libselinux.so.1 (0x00007fd074e57000)
libresolv.so.2 => /lib64/libresolv.so.2 (0x00007fd074e3e000)
liborc-0.4.so.0 => /lib64/liborc-0.4.so.0 (0x00007fd074dbc000)
libffi.so.6 => /lib64/libffi.so.6 (0x00007fd074db1000)
libpcre.so.1 => /lib64/libpcre.so.1 (0x00007fd074d3d000)
libpulsecommon-13.0.so => /usr/lib64/pulseaudio/libpulsecommon-13.0.so (0x00007fd074cb3000)
libX11-xcb.so.1 => /lib64/libX11-xcb.so.1 (0x00007fd074cae000)
libICE.so.6 => /lib64/libICE.so.6 (0x00007fd074c90000)
libSM.so.6 => /lib64/libSM.so.6 (0x00007fd074c85000)
libXtst.so.6 => /lib64/libXtst.so.6 (0x00007fd074c7c000)
libsndfile.so.1 => /lib64/libsndfile.so.1 (0x00007fd074c07000)
libasyncns.so.0 => /lib64/libasyncns.so.0 (0x00007fd074bfd000)
libdbus-1.so.3 => /lib64/libdbus-1.so.3 (0x00007fd074ba7000)
libcap.so.2 => /lib64/libcap.so.2 (0x00007fd074ba0000)
libGLX.so.0 => /lib64/libGLX.so.0 (0x00007fd074b6c000)
libXext.so.6 => /lib64/libXext.so.6 (0x00007fd074b57000)
libGLdispatch.so.0 => /lib64/libGLdispatch.so.0 (0x00007fd074a9a000)
libfreetype.so.6 => /lib64/libfreetype.so.6 (0x00007fd0749d7000)
libgraphite2.so.3 => /lib64/libgraphite2.so.3 (0x00007fd0749b2000)
liblz4.so.1 => /lib64/liblz4.so.1 (0x00007fd074991000)
libgcrypt.so.20 => /lib64/libgcrypt.so.20 (0x00007fd074873000)
libXau.so.6 => /lib64/libXau.so.6 (0x00007fd07486d000)
libbrotlicommon.so.1 => /lib64/libbrotlicommon.so.1 (0x00007fd074848000)
libblkid.so.1 => /lib64/libblkid.so.1 (0x00007fd0747f1000)
libpcre2-8.so.0 => /lib64/libpcre2-8.so.0 (0x00007fd07475f000)
libuuid.so.1 => /lib64/libuuid.so.1 (0x00007fd074755000)
libXi.so.6 => /lib64/libXi.so.6 (0x00007fd074743000)
libgsm.so.1 => /lib64/libgsm.so.1 (0x00007fd074732000)
libFLAC.so.8 => /lib64/libFLAC.so.8 (0x00007fd0746d6000)
libogg.so.0 => /lib64/libogg.so.0 (0x00007fd0746cd000)
libvorbis.so.0 => /lib64/libvorbis.so.0 (0x00007fd07469d000)
libvorbisenc.so.2 => /lib64/libvorbisenc.so.2 (0x00007fd0745f2000)
libbz2.so.1 => /lib64/libbz2.so.1 (0x00007fd0745de000)
libgpg-error.so.0 => /lib64/libgpg-error.so.0 (0x00007fd0745b9000)
So, I don't know whats happen, thank beforehand.
I had also problems using PT7.2 use PacketTracer 7.3 this works perfect for me!
Arik
Ok, thank you, I'm gona check it.
Shadow1
I have same problem, but ubuntu 22.04 on distrobox container. (version 8.2.2)
It helped me
terminal:
cd /opt/pt/bin/
and this command
./PacketTracer
and if outpot: libQt5NetworkAuth problems run this command
packettracer eth0
It helped me, maybe it will help others, so I'll leave it at that.
