trunking
food
Can a 4006 with a Supervisor II switching module trunk with a 4006 with a router module. Using the gbic for fiber connectivity.
2.I'm a newbie, what would be an example of the configuration to do this for each switch.
3. I believe I'll have to setup two vlans.? Is this correct.
Thank you
Dean
thank you
mahmoodmkl
Level 7
Level 7
Yes you can trunk with ports on SUP.
If u r having a VTP environment then u can create the vlans on the VTP Server it will automatically propogate to the client switches.
The config will look like this.
on 4006
set trunk 1/1 on dot1q
Mahmood
