07-20-2017 02:23 AM - edited 03-08-2019 11:23 AM
Hello friends,
Please, could you help me with
I have two working HP Procurve 3500
Port 36 of HP Procurve connected to port 43 of Cisco 2960
Port 36:
name "DEFAULT_VLAN"
untagged 1
no untagged 2-48
no ip address
exit
vlan 50
name "D VLAN 50"
untagged 2-48
qos priority 0
ip address 10.35.14.252 255.255.255.0
tagged 1
exit
vlan 150
name "V VLAN 150"
qos priority 5
ip address 10.100.52.3 255.255.255.0
tagged 1-48
voice
jumbo
exit
On Cisco port 43:
interface GigabitEthernet1/0/43
So, when I connect
But strange thing happen in this moment - I lose connection to
On HP switches I have route:
ip route 0.0.0.0 0.0.0.0 10.35.14.250
where 10.35.14.250 is voice Cisco gateway (this gateway also contain
Please, do you have any ideas?
Below conf for HP and for Cisco:
HP:
HP3500yl48G-SW02# show run
Running configuration:
; J8693A Configuration Editor; Created on release #K.14.41
hostname "HP3500yl48G-SW02"
time
module 1 type J86yyA
module 2 type J86xxA
interface 1
exit
interface 5
exit
name "DEFAULT_VLAN"
untagged 1
no untagged 2-48
no ip address
exit
vlan 50
name "D VLAN 50"
untagged 2-48
qos priority 0
tagged 1
exit
vlan 150
name "V VLAN 150"
qos priority 5
tagged 1-48
voice
jumbo
exit
mirror 1 remote ip 10.100.52.3 1000 10.100.52.2
timesync sntp
sntp unicast
sntp server priority 1 10.35.14.250 3
no ip ssh
snmp-server community "public" unrestricted
snmp-server community "itr" operator
snmp-server community "ITRW" operator
snmp-server contact "info" location "itrw"
spanning-tree
vlan 150
monitor all both mirror 1
exit
no autorun
Cisco:
cisco2960#show running-config
Building configuration...
Current configuration : 11842 bytes
! Last configuration change at 11:59:17 MGT Tue Jan 3 2006
version 15.0
no service pad
service password-encryption
hostname cisco2960
boot-start-marker
boot-end-marker
enable secret 5 $1$Sct1$28GNpkcgyfLeOUwyQ3zB81
no aaa new-model
clock timezone MGT 11 0
switch 1 provision ws-c2960s-48lps-l
ip routing
ip domain-name inltsos.com
mls qos map policed-dscp 0 10 18 24 46 to 8
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 50 200
mls qos queue-set output 1 threshold 2 125 125 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 150 50 200
mls qos queue-set output 1 buffers 15 25 40 20
mls qos
crypto pki trustpoint TP-self-signed-1724377984
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1724377984
revocation-check none
rsakeypair TP-self-signed-1724377984
crypto pki certificate chain TP-self-signed-1724377984
certificate self-signed 01
3082024D 308201B6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
quit
spanning-tree mode
class-map match-all AUTOQOS_VOIP_DATA_CLASS
match
class-map match-all AUTOQOS_DEFAULT_CLASS
match access-group name AUTOQOS-ACL-DEFAULT
class-map match-all AUTOQOS_VOIP_SIGNAL_CLASS
match ip dscp cs3
policy-map AUTOQOS-SRND4-CISCOPHONE-POLICY
class AUTOQOS_VOIP_DATA_CLASS
set dscp ef
police 128000 8000 exceed-action policed-dscp-transmit
class AUTOQOS_VOIP_SIGNAL_CLASS
set dscp cs3
police 32000 8000 exceed-action policed-dscp-transmit
class AUTOQOS_DEFAULT_CLASS
set
police 10000000 8000 exceed-action policed-
interface FastEthernet0
no
shutdown
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
spanning-tree
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface Vlan1
no
shutdown
interface Vlan50
interface Vlan150
no
permit
line con 0
line
end
Thank you.
