Layer 2 Problem on /23 Segment
M Rinaldy Aulia
Hi All,
We have a problem on our Network System.
Our customer have 2 segment interface vlan with /23 segment, and all using Metro-E layer 2 :
interface Vlan201
 description Voice
 ip address 172.27.76.1 255.255.254.0
 ip helper-address 169.7.76.71
interface Vlan774
 description VLAN for 169.7.76.0/23 Subnet for Data, Server, IP Management Devices (All Branch)
 ip address 169.7.76.49 255.255.254.0
 no ip route-cache
Topology :
Notes :
  • All Gateway on the Core (Head Office)
  • All Branch Dist Switch using L2 with Trunk Metro-E
  • Switch Branch only have interface vlan for IP management
  • Gateway interface vlan voice only available on the Core (Head Office)
Issue :
  • Branch Bekasi can't call to Branch Ceva
Troubleshooting had been done :
  • Create a dummy interface vlan voice on Branch Bekasi and Branch Ceva to check network issue
  • Interface vlan voice Branch Bekasi can't ping Interface vlan voice Branch Ceva
  • Interface vlan data Branch Bekasi able to ping interface vlan Data Branch Ceva
  • Interface vlan voice Branch Bekasi able to ping interface vlan Head Office and other Branch
  • Interface vlan voice Branch Ceva able to ping interface vlan Head Office and other Branch
  • Try to create interface voice vlan on Distribution Switch (2950) on Branch Bekasi, it was failed. One of them will down (Data / Voice), can't up together
Interface Vlan Voice (dummy) / Data can't up together, one of them will down :
Any advice?
Best Regards,
Rinaldy
does the voice VLAN even exist on the branch switches ? Usually, VTP takes care of propagating the VLANs across the switches. You only need one layer 3 (SVI) interface for each VLAN (which you already have configured on your Core).
What is the output of 'show vlan' on the 2950 switches ? Make sure your VTP domain is set up correctly...
