Trying to configure L3 Etherchannel 3845 ISR
mmedwid
Level 3
Level 3
When I try to add an IP address to a port-channel interface on a 3845 ISR I am getting an error that seems to
imply that only L2 etherchanneling is possible.  Am I missing something?
Cisco IOS Software, 3800 Software (C3845-ADVIPSERVICESK9-M), Version 12.4(24)T8,
sfo-c3845-1#sho run int port-channel 1
Building configuration...
Current configuration : 31 bytes
interface Port-channel1
end
sfo-c3845-1#config t
Enter configuration commands, one per line.  End with CNTL/Z.
sfo-c3845-1(config)#int port-channel 1
sfo-c3845-1(config-if)#ip address 10.10.36.91 255.255.255.0
% IP addresses may not be configured on L2 links Port-channel1.
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/prod_white_paper0900aecd806f698a.pdf
I tried spelling out this should not be seen as a switchport and this did not help..
sfo-c3845-1(config)#int Port-channel 1
sfo-c3845-1(config-if)#no switchport
Command rejected: not allowed under port channel.
Reza Sharifi
Can you try adding the physical ports to the portchannel first and then the IP address?
sfo-c3845-1(config)#int gig 0/0
sfo-c3845-1(config-if)#channel-group 1
Channel-group 1 does not exist in config
:-(  But it appears to infact be there..
end
Try the 4 port fast ethernet module instead of the embedded Gig..
sfo-c3845-1(config)#int fastEthernet 0/0/0
% Invalid input detected at '^' marker.
..Nope.
Not sure why this worked - but what did it was I deleted the two Port-channel interfaces that had been configured previously.  Then I rebooted and added Portchannel 10 and it let me add the IP address and join the Gig ints to the etherchannel.  Woohoo.
sfo-c3845-1(config)#int Port-channel 10
sfo-c3845-1(config-if)#interface gig
sfo-c3845-1(config-if)#interface gigabit 0/0 - 1
sfo-c3845-1(config)#interface range gig 0/0 - 1
sfo-c3845-1(config-if-range)#channel-group 10
%Interface MTU set to channel-group MTU 1500.
GigabitEthernet0/1 added as member-1 to port-channel10
