Trying to connect two 2960CX Series switches with SFP (GLC-BX10-U) modules using LC-LC UPC cable but not successful
ahmed.alghawas
Hi All,
I need help connecting two 2960CX Series switches with SFP (GLC-BX10-U) modules using LC-LC UPC cable but not successful.  The connectivity required is L2 as a trunk interface.
Appreciate your support,
Ahmed
Here are some details:
Switch #1:
Current configuration : 152 bytes
interface GigabitEthernet0/12
 switchport mode trunk
 speed nonegotiate
 udld port aggressive
 spanning-tree port-priority 240
end
Switch #2
 speed nonegotiate
end
show int g0/12
GigabitEthernet0/12 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 4cbc.48ad.a98c (bia 4cbc.48ad.a98c)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 1000 usec,
  Keepalive not set
  Auto-duplex, Auto-speed, link type is force-up, media type is 1000BaseBX10-U SFP
  input flow-control is off, output flow-control is unsupported
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  192.168.2.7     YES NVRAM  up                    up
GigabitEthernet0/1     unassigned      YES unset  up                    up
GigabitEthernet0/2     unassigned      YES unset  down                  down
GigabitEthernet0/3     unassigned      YES unset  down                  down
GigabitEthernet0/4     unassigned      YES unset  down                  down
GigabitEthernet0/5     unassigned      YES unset  down                  down
GigabitEthernet0/6     unassigned      YES unset  down                  down
GigabitEthernet0/7     unassigned      YES unset  down                  down
GigabitEthernet0/8     unassigned      YES unset  down                  down
GigabitEthernet0/9     unassigned      YES unset  down                  down
GigabitEthernet0/10    unassigned      YES unset  down                  down
GigabitEthernet0/11    unassigned      YES unset  down                  down
GigabitEthernet0/12    unassigned      YES unset  down                  down
Port-channel1          unassigned      YES unset  down                  down
show ver
Cisco IOS Software, C2960CX Software (C2960CX-UNIVERSALK9-M), Version 15.2(7)E2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Sat 14-Mar-20 18:35 by prod_rel_team
ROM: Bootstrap program is C2960CX boot loader
BOOTLDR: C2960CX Boot Loader (C2960CX-HBOOT-M) Version 15.2(6r)E, RELEASE SOFTWARE (fc1)
Admin uptime is 55 minutes
System restarted at 11:11:48 UTC Mon Jun 1 2020
System image file is "flash:c2960cx-universalk9-mz.152-7.E2/c2960cx-universalk9-mz.152-7.E2.bin"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960CX-8PC-L (APM86XXX) processor (revision L0) with 524288K bytes of memory.
Processor board ID FOC2312Y3CH
Last reset from power-on
1 Virtual Ethernet interface
12 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 4C:BC:48:AD:A9:80
Motherboard assembly number     : 73-100862-04
Power supply part number        : 341-0675-02
Motherboard serial number       : FOC23114XUX
Power supply serial number      : LIT23012XFY
Model revision number           : L0
Motherboard revision number     : C0
Model number                    : WS-C2960CX-8PC-L
System serial number            : FOC2312Y3CH
Top Assembly Part Number        : 68-100568-01
Top Assembly Revision Number    : E0
Version ID                      : V03
CLEI Code Number                : CMMT410BRB
Hardware Board Revision Number  : 0x09
Switch Ports Model                     SW Version            SW Image
*    1 12    WS-C2960CX-8PC-L          15.2(7)E2             C2960CX-UNIVERSALK9-M
Configuration register is 0xF
Admin#
2 Accepted Solutions
Giuseppe Larosa
Hello @ahmed.alghawas ,
you need a different type of SFP on one side.
look at the following
https://www.optcore.net/product/cisco-glc-bx-u-compatible-1000base-bx10-u-smf-tx1310nmrx1490nm-10km-sfp-transceiver/
This special type of SFP are made to work on a single fiber and onde side transmits at 1310 nm and receives at 1490 nm the other side must do the opposite.
the other side must be of type final D
https://www.optcore.net/product/cisco-glc-bx-d-compatible-1000base-bx10-d-smf-tx1490nmrx1310nm-10km-sfp-transceiver/
if you have two fibers avaiable you can use more conventional SFP, if you have only one you need two SFPs of different types.
Hope to help
Giuseppe
Thank you!
Yes, I was using GLC-BX-U on both sides which is incorrect.
Giuseppe Larosa
Hope to help
Giuseppe
Thank you!
Reza Sharifi
Looking at the Cisco transceiver matrix document, it appears that "GLC-BX10-U" is not supported but  "GLC-BX-U" is.
https://tmgmatrix.cisco.com/?si=2960CX
Thanks for your input bro.
GLC-BX10-U is same as GLC-BX-U (10km).
