TTY error
senthil1976
Hi All,
I am getting an following error in Cisco7400,
TTY2: timer_create_bg error
what this means?
regards,
Senthil
amin.amor
Try to modify telnet timers.
A.Amor
IP consultant
http://www.amortel.com
Your network partner in Luxembourg
http://www.itnet.lu
Yes, if you modify the timeout nyour issue will be solved, but, could you tell me waht v. of IOS are u running?
Maybe you need a upgrade ;)
Amin, I understand it is something to do with timers, but what is it all about? Could you explain what is going on here, and how you arrived at the solution of modifying the telnet timers? I would like to understand better.
Kevin Dorrell
Luxembourg
I hear that was fixed in 12.2(16)B, just a minor issue.
Ariel
