Turbo ACL
stevenormoyle
I am looking for information that will explain the output of the command show access-list compiled. I have included the output from a 7206 router. I know Turbo ACL creates a table for lookups for speed. As I look at the output I would like to know what is meant by some of the following:
Config Fragment and then the output where it shows Table expands. For example on the line that starts with L0 what is meant by all the output on that line.
Compiled ACL statistics:
ACL State Entries Config Fragment Redundant
in2out Operational 1072 963 125 16
2 ACLs, 1 active, 1 builds, 1072 entries, 1056 ms last compile
0 history updates, 2000 history entries
0 mem limits, 128 Mb limit, 3 Mb max memory
0 compile failures, 0 priming failures
Overflows: L1 0, L2 0, L3 0
Table expands:[9]=0 [10]=0 [11]=0 [12]=0 [13]=0 [14]=0 [15]=0
L0: 2001Kb 6/7 20/21 26/27 514/515 623/624 19/20 62/63 5/6
L1: 110Kb 2/150 2/250 2/250 2/150
L2: 7Kb 2/300 2/300
L3: 3Kb 2/1072
Ex: 209Kb
Tl: 2333Kb 1289 equivs (14 dynamic)
Thanks for the help
owillins
Level 6
Level 6
