09-08-2023 02:10 AM
I've set up multiple interfaces (both access & trunk) on a switch with sticky learning like this:
switchport port-security maximum 10
switchport port-security mac-address sticky
The trunk interfaces also run 8 VLANs.
The switch has learned 5 MAC addresses.
How can I now turn off sticky learning WITHOUT losing the already learned addresses?
Ideally, I want to turn it off and write the learned MACs to the startup-config.
"no switchport port-security mac-address sticky" deletes all the learned MACs.
What I'm trying to achieve (this isn't my idea of port-security but what the customer explicitly wants…):
Turn on port-security with sticky learning. Give the whole system an hour to learn all trustworthy MACs.
After one hour, have a PEBKAC user turn off learning and have a system with "static" MAC port-security going forward.
09-08-2023 02:55 AM
Personallu i will add stick mac address you want to retain in the learned on dynamically to static and remove dynamic sticky option.
switchport port-security mac-address sticky XXX1
switchport port-security mac-address sticky XXX2
09-08-2023 03:45 AM
Thanks for your answer.
This again would add the address as a "sticky" MAC - right?
And they would be deleted after "no switchport port-security mac-address sticky".
Wouldn't you want to do "switchport port-security mac-adress a.b.c" instead?
That way the addresses should be retained after "no switchport port-security mac-address sticky".
09-08-2023 10:52 AM
switchport port-security mac-address sticky - Dynamically learning
switchport port-security mac-address sticky xxx - you configuring statically only allowed in that port.
yes that can be also used - If you enable sticky learning after you enter this command, the secure addresses that were dynamically learned are converted to sticky secure MAC addresses and are added to the running configuration.
