TwinGIG Ten gig conversion to 1 GIG interfaces
m-abooali
Level 4
Level 4
                   hi,
I have this 4507 chassis, SUP 6L-E. it has two twin giog ports an di had trie dto configure these as 1 gig interfaces to be used as i gig uplinks. after inserting teh commands I found in a Cisco paper, I see that only ports 5 & 6 works but not 3 & 4 (3 & 4 are the first twin gig).
is this suppose to behave like this?
why 5 & 6 and not 3 & 4?
I did active all of them tho?
interface GigabitEthernet3/3
description uplink to Core 6500 Gi1/1/11 on primary
switchport mode trunk
shutdown
channel-group 1 mode on
interface GigabitEthernet3/4
description uplink to Core 6500 Gi2/1/11 on Secondary/stby Sw
shutdown
interface GigabitEthernet3/5
interface GigabitEthernet3/6
shutdown
shutdown
Pleasew advise,
Masood
krahmani323
Level 3
Level 3
Hello Masood,
Correct me if I am wrong, but you are using two 4507 chassis with SUP 6L-E in standalone mode.
To change from the default 10G mode to 1G mode, you have configured the commands :
hw-module module 3 port-group 1 select gigabitethernet
hw-module module 3 port-group 2 select gigabitethernet
If this is the case  It should work even with 4x 1G active (in standalone mode only).
In the posted configuration we are seeing the mentionned interfaces (Gi3/3 and Gi3/4) as shutdown. Is it normal ?
Best regards.
Karim
I only have one 4507 chassis an di tried to convert the 10 gig uplinks to 1 gig 3 -6
here is what I have on teh switch:
4507r-flr-2600k#sh hw-module slot 3 port-g
4507r-flr-2600k#sh hw-module slot 3 port-group 1
Module Port-group Active                         Inactive
   3        1     Te3/1                          Gi3/3-4
4507r-flr-2600k#sh hw-module slot 3 port-group 2
   3        2     Gi3/5-6                        Te3/2
I did shut those port gi 3/3 and gi 3/4 because they were not becomming active.
is teh output of sh hw-module slot 3 port-group 2 good enough and must work?
Masood
Hello Masood,
This is the reason why => the port group 1 (first slot) is not configured in Giga mode but is still in TenGig default mode.
   3        1     Te3/1                          Gi3/3-4
If you associate the port group 1 in 1G mode with the following command =>
Then it should work.(I would advice to be careful for any manipulation in production environment).
Best regards.
Karim
