two default route to internet on same spoke router
jomo frank
Hello Expert,
I have a hub and spoke network,which  has line redundancy configured for all spoke connection.
I am using eigrp as the routing protocol for all routing expected for the internet route, which use
a default route configured on each spoke.
To achieve line redunancy there are  two connections, wireless (primary connection)  and ip dsl (secondary connect) from hub
to each spoke.
I am using two default route so that in event of  line failure (wireless or id dsl ) the path to the internet should be reachable.
I notice  with this approach/method I am having problems when the primary connection drops the failover
to secondary(ip dsl line) is seemless for the eigrp generated routes, but the default route does not
change.
I was hoping that when the first default route becomes unavailable the second would be use but this
Not happening.
Jomo
2 Accepted Solutions
Ed Willson
Hey Jomo,
     I'm thinking perhaps IP SLA might fit the bill. I used the following link for a branch that is multi-homed to reach the HQ for internet access:
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/813-cisco-router-ipsla-basic.html
    Ed
Hi Jomo,
I think what you are looking for is floating static  routes.Because your example with different AD will work if interface  will be down. But when you loose connection and if interface stays up.  It won't help.
There is great resource that will help you.
Hope it will help.
Please rate helpful posts.
Best regards,
Abzal
8 Replies 8
Rahul Kukreja
Jumo,
I took a look at the attached configuration, you are using the permanent keyword with the static route
ip route 0.0.0.0 0.0.0.0 Tunnel0 permanent
ip route 0.0.0.0 0.0.0.0 Tunnel1 permanent
Permanent keyword specifies that the route will not be removed, even  if the interface shuts down.
http://www.cisco.com/en/US/docs/ios/iproute_pi/command/reference/iri_pi1.html#wp1037816
EIGRP neighbors (so in turn the routes learned from that neighbor) should go down if the hello packets are not received, but static routes may not.
Also in the above desciption - it is specified that the routes are primary/backup and in the configuration - the AD value for both the routes is same.
- HTH
Rahul
hello Rahul,
If i change the metric at the end of the route and remove permanent as per example should this be be okay?
ip route 0.0.0.0 0.0.0.0 Tunnel0 2
ip route 0.0.0.0 0.0.0.0 Tunnel1 3
Hi Jomo,
Hope it will help.
Best regards,
Abzal
I concur - I posted the same link last week
If you want the static routes to be used, one as the primary and one as the backup then all you need is the following:
ip route 0.0.0.0 0.0.0.0 Tunnel1 100
This places the AD on the backup and will be used in the event Tunnel0 goes down.
Rick - If you have two statics in there the best one will remain in the routing table. I'm pretty sure that's not going to work as the static is still there even if the link is down.
Ed,
When using the interface at the end of a static route the route will be injected into the routing table as long as the interface is up.  In this config:
This is telling the routing table to inject the route based on what interface is up.  If both tunnels are up then tunnel 1 will not be the primary because of the AD.  If tunnel 0 goes down then the route is withdrawn.  This leaves Tunnel 1 as the preferred route in the table.
Ed Willson
Hey Jomo,
    Ed
