Showing results forĀ
Search instead forĀ
Did you mean:Ā
VLAN ACL problem
radoslav-drabik
Level 3
Level 3
I know there are many posts here about VLAN ACL problem but I still cannot understand how it works.
I am trying to block access to server 8.8.8.8 for the host on VLAN 100 (host IP: 10.0.0.1). See my topology&config below. I have tried to place the  VLAN access list named "Block" on Vlan 100, in direction but it didn't work. The PC's default gatewy is SVI 100 IP address.
Can somebody explain it to me?
IOS: c2960s-universalk9-mz.122-58.SE1.bin
Interface vlan 10
ip address 192.168.10.1 255.255.2550
Interface vlan 100
Ip address 10.0.0.1 255.255.255.0
ip access-group Block in            <-it should block access to server 8.8.8.8 from 10.0.0.1
ip access-list extended block
deny   ip host 10.0.0.1 host 8.8.8.8
permit ip any any
The block access list is applied to the wrong vlan. You should apply it to vlan401 interface and you should be good...
From an "In" perspective, it is for hosts that are on the subnet that the vlan interface supports. Your vlan11 supports hosts in the 10.0.1.x range. Hosts in that range (10.0.1.17 - 10.0.1.22) would be affected by an "in" acl on vlan 11, but no other ranges.
HTH,
John
*** Please rate useful posts ***
HTH, John *** Please rate all useful posts ***
9 Replies 9
Abzal
Level 11
Level 11
The ACL looks ok for me, but name of ACL different on interface and ACL configured. Access list names are case sensitive. Try this:
Interface vlan 100
ip access-group block in
permit ip any any
Hope it will help.
Please rate helpful posts.
Best regards,
Abzal
Hi..sorry. that was just a typo. The names match.
Can you post your switch config?
Ok, what about ip address of host in ACL are trying to block access to your default gateway of VLAN 10.0.0.1?
Yes, like this ACL won't work. Host ip address in ACL. After that try to check.
If you want to block all hosts:
deny   ip any host 8.8.8.8
permit ip any any
Hope it will help.
Best regards,
Abzal
From what I can see from the picture, the PC and interface vlan 100 have the same IP address?
Changing that should fix it.
  Good catch you can't have the pc address the same as your default gateway for the subnet.  Change the pc something like .2 and readjust your acl to reflect that.
They don't have the same IPs. It is an another type . I will paste a config file tomorrow. Thanks.
Hi again,
It seems to be working now. I found a mistake in access list "block". I was allowing the whole network and then blocking few hosts. When I turned it around it started to work.
permit ip 10.0.0.0  0.0.0.255 any
deny   ip host 10.0.0.194 host 8.8.8.8
permit ip any any
working:
permit ip any any
But I have another scenario which I don't understand. I am trying to place an access list on the uplink VLAN interface 11. Here is the config.
interface GigabitEthernet1/0/2    <- To host
description Voice gateway
switchport access vlan 401
switchport mode access
interface GigabitEthernet1/0/25  <- To uplink
description UPLINK
switchport access vlan 11
interface Vlan401                         <- VLAN for hosts
ip address 10.0.0.193 255.255.255.192
interface Vlan11                           <- VLAN for Uplink
description UPLINK VLAN
ip address 10.0.1.18 255.255.255.248
switch#show ip route
S*    0.0.0.0/0 [1/0] via 10.0.1.17
deny   ip host 10.0.0.194 host 8.8.8.8     <- it doesn't seem to block the traffic to host 8.8.8.8
permit ip any any
Is it because it doesn't cross the VLAN interface. Am I right?
HTH,
John
