TWO INTERFACES SAME SUBNET(R)
isaaco001
Level 5
Level 5
Dear Community,
I would like to have my router 2911 to have two interfaces with the same ip for the LAN,however, i have limited L3 devices so its just one router and two L2 switches. vrrp,glbp or hsrp or subif's is not to be used.What can be done?Thank you all.
Isaac.
2 Accepted Solutions
Julio E. Moisa
You cannot have 2 interface at the same subnet on the same router because they will overlap each other, but you can create a bridge group and associate your interfaces to it and you will have only 1 IP on the router.
Example:
Router
interface Fa0/0
no ip address
bridge-group 2
interface Fa0/1
no ip address
bridge-group 2
interface BVI2
ip address 10.10.2.1 255.255.255.0
bridge irb
bridge 2 protocol ieee
bridge 2 route ip
Switch 1
vlan 2
interface Vlan2
ip address 10.10.2.2 255.255.255.0
end
Switch#ping 10.10.2.3
Sending 5, 100-byte ICMP Echos to 10.10.2.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Switch 2
vlan 2
interface Vlan2
ip address 10.10.2.3 255.255.255.0
end
Switch2#ping
*Feb 13 13:06:47.111: %SYS-5-CONFIG_I: Configured from console by console
Switch2#ping 10.10.2.1
Sending 5, 100-byte ICMP Echos to 10.10.2.1, timeout is 2 seconds:
Switch2#ping 10.10.2.2
Sending 5, 100-byte ICMP Echos to 10.10.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/2 ms
Switch2#ping 10.10.2.3
Success rate is 100 percent (5/5), round-trip min/avg/max = 5/5/5 ms
Switch2#
Please rate the comment if it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Isaac,
You are welcome, Yes this IP can be used on routing processes like any IP on a router.
6 Replies 6
Julio E. Moisa
Example:
Router
interface Fa0/0
no ip address
bridge-group 2
interface Fa0/1
no ip address
bridge-group 2
interface BVI2
bridge irb
bridge 2 route ip
Switch 1
vlan 2
interface Vlan2
end
Switch 2
vlan 2
interface Vlan2
end
Switch2#ping
Switch2#
Julio,
Thanks for your response. However, i have concerns that need to be settled.This bvi ip should act like any other ip i.e routable with no glitches(caveats),right?Its just odd..
Isaac.
Hi Isaac,
Jubei
Frequent Visitor
Frequent Visitor
I know this is an older post but, I was working on a lab using VRF; in that specific instance, you can have the same IP address on two separate interfaces within the same router. Without VRF running it won't work.
boot-end-marker
vrf definition Client-A
address-family ipv4
exit-address-family
vrf definition Client-B
address-family ipv4
exit-address-family
no aaa new-model
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
no ipv6 cef
interface Ethernet0/0
vrf forwarding Client-A
interface Ethernet0/1
vrf forwarding Client-B
interface Ethernet0/2
no ip address
shutdown
interface Ethernet0/3
no ip address
shutdown
True, but it may be unknown, to OP or some readers, such identical IPs cannot be within the same IP domain.
Ricky Sandhu
Level 5
Level 5
Currently working on my CCIE EI lab in GNS3 and I noticed on a given router, I can have two serial interfaces using the same IP configuration.  Is it because serial interfaces are point-to-point and theoretically can be connected to different networks using the same IP schema?
Serial1/0 10.1.10.10 YES NVRAM up up
Serial1/1 10.1.10.20 YES manual up up
