Switching
Labels
Welcome to the Cisco Community Ask Me Anything conversation. Submit your questions from Monday, February 2, 2026, through Friday, February 20, 2026. Our colleagues Amruta Navadagi, Anaya Kalawat, and Mohammad Mehtabuddin will be waiting to assist you...
amnavada by • Cisco Employee
  • 17662 Views
  • 36 replies
  • 2 Helpful votes
Can anyone explain why a burned-in MAC address might deviate from the logical numbering scheme? Typically, the MAC addresses for a switch’s ports begin with a base MAC address and increment in sequence, corresponding to the port numbers. In our case,...
Tec1do by • Community Member
  • 439 Views
  • 12 replies
  • 1 Helpful votes
Hi everyoneOur SFP-10G-ER modules aren't recognized as supported by a C9300-24S with C9300-NM-8X. According to the compatibility matrix, they should be compatible.We tried workarounds I've found for similar errors, like cold-boot the switch several t...
cjaras by • Community Member
  • 267 Views
  • 6 replies
I want to limit the bandwidth for specific traffic from a server on the Catalyst 9000.Is the following policing configuration correct?I want to control the bandwidth on the inbound direction of the interface connected to the server.Also, am I correct...
CHISHIUNG by • Spotlight
  • 302 Views
  • 6 replies
Hey all,Long story short;I have a C2960G-24TC-L here that had sw version that was incapable of crypto keys. The goal being able to ssh into it..The state of this thing now is pretty much blank after after formating the flash like a dummy beacause of ...
Dear Team,   I am unable to upgrade my cisco switch image & getting below error. Also from same tftp i am able to upgrade WLC imagealso able to take backups & everything but not able to upgarde image. ICMP ping  is good between user machine & TFTP se...
yogesh1 by • Level 3
  • 1948 Views
  • 6 replies
Hello everyone!I am studying enterprise network design and working on a diploma project based on Cisco's three-layer hierarchical network architecture.I would like to understand how network engineers decide which types of network devices are needed i...
I don't fully understand how the following configuration works—will QoS be controlled correctly?The service policy applied to the interface is TRAFFIC_PRIORITY, but the MARK_QOSGROUP in the policy map is not applied to any interface.In terms of how t...
  • 173 Views
  • 2 replies
Hello everyone,For a scenario like the diagram uploaded, what is the cisco solution to symmetrically load balance traffic between servers and the switches work in active-active HA mode?I have used nexus 9k switches.I used vPC but it sends same flows ...
elahe by • Level 1
  • 1875 Views
  • 7 replies
