Two ISP, HSPR, BGP, Load Balancing and Failover.
staticprop
I am trying to setup a scenario in my lab for a customer and need some configuration help.
Background: My customer has a class C block of public IP addresses behind two border routers. Each router is connected to a different ISP. Both routers are configured to use HSRP for failover and load balancing the outbound the traffic between the two ISP. Customers has a registered ASN with IBGP between the two routers and EBGP with each ISP. If the ISP sends out a maitenance notification stating the core router is going down for maintenance they have to manually initiate HSRP failover to send traffic to the other ISP. The reason being something is not configured properly.
1. Primary goal is to test and verify an automatic failover solution when an the upstream ISP core router goes down for service. Not the directly connected neighbor.
2. Need the config verified (leaving out template router commands and BGP route filters) by peers.
The Lab: Four Cisco routers.
Router 1 and Router 3 are used for the customer network
Router 2 and Router 4 are used for ISP 1 and ISP 2.
|  2    |    |  4    |
|  1    |    |  3    |
#### Router 1 Configuration (Customer Owned) ####
interface Ethernet0/0
ip address 10.20.20.5 255.255.255.0
no ip redirects
standby 1 ip 10.20.20.10
standby 1 priority 105
standby 1 preempt
standby 1 track Ethernet0/1
standby 2 ip 10.20.20.20
standby 2 prempt
standby 2 track Ethernet0/1
interface Serial0
description P2P with ISP 1
ip address <public-routable.1> 255.255.255.252
router bgp 64512
no synchronization
bgp log-neighbor-changes
network 10.20.20.0
neighbor <public-routable.3> remote-as 64513
neighbor 10.20.20.6 remote-as 64512
neighbor 10.20.20.6 next-hop-self
no auto-summary
ip classless
ip route 10.20.20.0 255.255.255.0 Null0
#### Router 2 (ISP Owned) ####
description P2P with Customer
ip address <public-routable.2> 255.255.255.252
no ip directed-broadcast
interface Ethernet0/1 (Connected to a switch at the moment. I figure I may need another device to configure with a different ASN to push routes from. Not sure???)
ip address 30.30.30.5 255.255.255.0
router bgp 6513
no synchronization
network 30.30.30.0 mask 255.255.255.0
neighbor <public-routable.1> remote-as 64512
no auto-summary
#### Router 3 Configuration (Customer Owned) ####
interface Ethernet0
ip address 10.20.20.6 255.255.255.0
no ip redirects
standby 1 preempt
standby 1 track Serial0
standby 2 priority 105
standby 2 prempt
standby 2 track Serial0
description P2P with ISP 2
router bgp 64512
no synchronization
network 10.20.20.0
neighbor <public-routable.4> remote-as 64515
neighbor 10.20.20.5 remote-as 64512
neighbor 10.20.20.5 next-hop-self
no auto-summary
ip classless
#### Router 4 (ISP Owned) ####
ip address <public-routable.4> 255.255.255.252
ip address 40.40.40.5 255.255.255.0
router bgp 64515
no synchronization
neighbor <public-routable.2> remote-as 64512
no auto-summary
Thanks for the advice, help or silly comments.
sp
tironevi
Does the ISP advertise any routes to the customer routers? If so you can configure tracking of these routes. So basically if there is an outage in the providers network these routes should no longer appear in the customer RIB. With tracking of routes enabled HSRP will decrement its priority should the routes disappear from the RIB.  BTW are any routes exchanged between the ibgp session? If you need a config example for this let me know.
Yes. Both ISP advertise routes received from peers. No internal routing. Routers 1 and 3 are the only ones on the internal network. Advertising a single prefix.
I read a little bit on this here:
http://www.cisco.com/en/US/docs/ios/ipapp/configuration/guide/ipapp_eot.html#wp1054699
It looks like this is the command needed.
track object-number ip route  ip-address/prefix-length reachability
A sample config would be great.
sp
tironevi
Not sure if your issue is resolved, but here is a quick example....
Lets say that ISP A advertises prefix 31.31.31.0/24 to the customer router you can configure HSRP in the following way
track 30 ip route 31.31.31.0 255.255.255.0 reachability
interface ethernet0
no ip redirects
standby 1 preempt
standby 1 track 30
standby 2 prempt
standby 1 track 30
The same logic can be applied to routes that are advertised from ISP B.
Keep in mind to accomplish what you want, it is key that you track prefixes that originated beyond the onsite Provider Routers (R2,R4). Also, for this work you cannot exchange the tracked prefixes between the customer routers (R1-R3). Based on what you said earlier you are only exchanging only local prefixes, but from the config extract you provided I see nothing preventing the exchange of provider learned prefixes between the R1 and R3.
Also to build some resiliency, you may want to track more then one prefix to ensure it is a network a true outage and not just one prefix issue. This can be done by configuring track list....I can help you with that if needed, but first verify if the above meets your requirements.
