two routes summarise
azmath.hk
We are running OSPF routing protocol and we want to dvertise only the two summarize routes 10.8.0.0/16 and 10.4.0.0/16 on our perimeter devices(cisco routers) which are connected to our collabarative network.
Is it possible to advertise two sumarize router 10.8.0.0/16 and 10.4.0.0/16 ?
satish_zanjurne
Level 4
Level 4
Can you post the config of the router ??
Istvan_Rabai
Level 7
Level 7
Hi Azmath,
Based on the scarce information I have from your post, I can ask you the following:
Why don't you advertise the summarized route of the 2 above: 10.0.0.0/12 ?
Cheers:
Istvan
But finally, if you want, you can use the "area range" command multiple times to advertise the 2 summaries.
Cheers:
Istvan
