Two same mac address learning on single port
Multiple vlans can be configured on the same mac and on the same port.
1 18b1.692e.c100 DYNAMIC Gi1/0/1
11 18b1.692e.c100 DYNAMIC Gi1/0/1
@kamleshkatariya1994
Yes, the scenario you described, where the same MAC address (`18b1.692e.c100`) appears on multiple VLANs on the same port  connecting to a Firewall, can indeed cause MAC flapping. MAC flapping occurs when the switch receives frames with the same source MAC address on different ports or VLANs in a short period of time, leading to continuous updates in its MAC address table. This typically happens due to misconfigurations in trunk ports or VLAN tagging issues. In this case, the port Gi1/0/1 should be correctly configured as a trunk port, and the firewall must appropriately tag VLANs to prevent confusion. T
Troubleshoot this! Verify the trunk configuration on the switch to ensure the appropriate VLANs are allowed and properly tagged. For instance, the switch port configuration should allow VLANs 1 and 11. On the firewall, ensure that interfaces handling VLANs are set up correctly, tagging traffic with the right VLAN identifiers.
Best regards
14 Replies 14
Torbjørn
This can occur for multiple reasons. It could also be caused by having VLANs that have been bridged together somewhere else in the topology. Some devices simply use the same mac address in multiple VLANs. You can see this when a device has transitioned from one VLAN to another.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
hello
Is this the cause of Mac flapping?
M02@rt37
hello @kamleshkatariya1994
If Gi1/0/1 is a trunk port, it can carry traffic for both VLAN 1 and VLAN 11. The device with the MAC address 18b1.692e.c100 might be connected to another switch or router through this trunk port.
Best regards
hello
Gi1/0/1 connects to firewall and configures 2 vlans, and 2 vlan mac are same
Best regards
Thanx for support
It is third time you post aboue same issue.
I dont think it solve (let discuss this issue here please no private message'let all know exactly the issue and how we can solve it)
Now
History of issue
You have ring topolgy
The SW face this issue is SW that connect to 802.1D (legacy)' i.e. legacy SW is inbetween two SW run PVST.
So the solution of this issue is make this SW run PVST' i.e. all SW run same STP mode
Waiting your reply
MHM
hello
Yes all SW run same STP mode (PVST)
If So what I see is say different
Below is your show in your first post which fast mark as solve and I was sure it not native vlan issue anyway
VLAN0001
Spanning tree enabled protocol rstp
Root ID Priority 32768
Address 0087.64b6.c5f7
Cost 90
Port 1 (GigabitEthernet1/1)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1)
Address 0029.c2a1.e200
Aging Time 300 sec
Interface Role Sts Cost Prio.Nbr Type
Gi1/1 Root FWD 4 128.1 P2p Peer(STP)
Gi1/2 Desg FWD 4 128.2 P2p Peer(STP)
Peer(STP) this meaning that this SW is run pvst and connect to stp legacy SW
MHM
hello
All the Switches are connected in PVST but when i start the ring then the port remains blocked for some time and after some time it comes in the listing, below details
VLAN0001
Spanning tree enabled protocol ieee
Root ID Priority 1
Address 0078.8822.cc00
Cost 24
Port 25 (GigabitEthernet1/0/25)
Address b08b.d067.dd80
Aging Time 300 sec
Gi1/0/25 Root FWD 4 128.25 P2p
Gi1/0/26 Altn BLK 4 128.26 P2p
VLAN0011
Root ID Priority 11
Cost 24
Bridge ID Priority 32779 (priority 32768 sys-id-ext 11)
Aging Time 300 sec
Gi1/0/11 Desg FWD 19 128.11 P2p
Gi1/0/12 Desg FWD 19 128.12 P2p
Gi1/0/13 Desg FWD 19 128.13 P2p
Gi1/0/15 Desg FWD 19 128.15 P2p
Gi1/0/17 Desg FWD 19 128.17 P2p
Gi1/0/18 Desg FWD 19 128.18 P2p
Gi1/0/19 Desg FWD 19 128.19 P2p
Gi1/0/20 Desg FWD 19 128.20 P2p
VLAN0001
Root ID Priority 1
Cost 24
Aging Time 300 sec
VLAN0011
Root ID Priority 1
Cost 24
Port 26 (GigabitEthernet1/0/26)
Aging Time 15 sec
Gi1/0/25 Desg FWD 4 128.25 P2p
Gi1/0/26 Root LIS 4 128.26 P2p
Only check your first post' what I share above from your post
Where you see peer (stp) ?
It can the issue here
MHM
Joseph W. Doherty
Yes they can.  MACs only need to be unique per L2 domain.  As you mention two VLANs, that's legitimate.
From your other replies, you ask if this can cause MAC flapping.  If all is configured correctly, and working correctly, no it shouldn't.
If you have MAC flapping, we need more detail, starting with what do you see/consider the MAC flapping?
@MHM Cisco World mentions this is your 3rd post same issue?
hello
Tell me what details you need and i will send it to you.
Just took a look a your prior postings.  I, like @Giuseppe Larosa (in one of those prior threads) wonder about the size of your ring topology, especially using non-rapid-pvst.  More suitable for this topology might be REP, but possibly not all your switches support, but if they rapid-pvst, I would suggest migrating to that.  Believe it's a bit more tolerant on "diameter".
